Using Phone to connect to Wifi, but needs ADSL User name and Pass?
kaisterkai
Good day..
i have a phone that can connect to a wifi, but the thing is now, at home I need the ADSL User name and Pass, but the thing is.. I dont' know how to add that to the connection.. if you know what I mean...
Because I can't seem to go on the internet even when I'm connected to the router at home..
Has anyone solves this before? If so, please help..
bwana
MyBroadband
Super Moderator
You need to let the router deal with the adsl connection because afaik the phone can't handle pppoe itself.
Venomous
setup the adsl/router via a pc. Add wifi password.
Search for avail wifi on your cell. Select your wifi router. Add your wifi password you set up......
kaisterkai
Thought so, but how does the router deal with the conenction? Because It's not working with my phone.. :(
kaisterkai
Well my router is set up.. Like I can use it with my PC.. but not with my phone.. (IF that is the setup you're refering to.. :) )
Venomous
ok, so you know it works :)
have you set up wifi with a password(key), for you own protection, must be done on your pc....
kaisterkai
Yeah my Router already has a WPA pass, but the thing is.. it's needs other log-ins for my Telkom user.. that which I do not know how to setup..
Jennifer Lopez
I am connected to my router - well it says connected - but I can't surf. How do I setup up my axxess adsl username and password on the phone
Venomous
Your router needs to be connected to the internet ( you should see that on a PC for example...
You should have a wifi enabled router
Your router should have wifi turned on
Your router should have a wifi password
search for the wifi network on your cell.
enter the wifi password.
now you should be able to connect
Leimie
Your router is using bridged mode. You need to set it up using routed mode. That way your router connects to the net and you connect to the router. You need to log onto the router using a pc and insert your isp details on the routers "interface."
Sent from my HTC Desire using MyBroadband Android App
Jennifer Lopez
AHA!
Thank you
