Using Topaz Sharpen AI with Photoshop as a plugin
Vikki Sixx
Hi All,
I am trying to install and use TOPAZ SHARPEN AI as a plugin on my Photoshop but while I can install it successfully, I cannot use it.
After installing the plugin in the plugin folder and then starting Photoshop, I get a warning about a plugin not being available (see image attached 01)
Then when I go to use it and I look for it under the normal PS location > Filter>Topaz Plugin>Topaz Sharpen AI it is there but if I try to open it I get the second error message (see attached image 02) and then Photoshop crashes.
Any ideas why or how to fix this.
I am using Photoshop 2020 and Topaz Sharpen AI v1.4.4
Vic
