Hi Guys
If someone has already posted about this. Soz.
It's very NB. I only found out about this yesterday.
Please note that your power cord needs to have a
red plug
with the flattened earth pin. Without this red plug type you will not be able to plug into the power grid. Each multiplug that we supply is meant to have two PC’s plugged into it. So if you and your buddy only use two plugs because you have a power lead with multiple points, it does not mean you have two additional plugs to use for whatever. The power is calculated according to the PC’s, and deviating from this might cause power failures
http://www.nag.co.za/e107_plugins/forum/forum_viewtopic.php?57474
Under "What to Bring"...
