With all these price cuts I dont see virgin lasting much longer.
I'm sure they'll do something sooooon
MTNDD
Your 128k sim swap didn't fix the problem then?They can't even handle existing network load, price cuts are likely to make it even worse.
Your 128k sim swap didn't fix the problem then?![]()
I didn't get one.Using MTN now, still got airtime on my Virgin sim so I've tried it every now and then so I can at least use it up but its too slooooooooooooow.
Gerald will be on your case if you didn't contact himI didn't get one.Using MTN now, still got airtime on my Virgin sim so I've tried it every now and then so I can at least use it up but its too slooooooooooooow.
Gerald will be on your case if you didn't contact him(stalker)
You guys forget one thing.At least on Virgin my hard earned data credit carries over.Dont get me wrong they have probs but they dont hold you by the balls!
Also on mtn as long as that promo continues.....
