Nod
- Jul 22, 2005
Source: HowtoForge
Go to the source for the rest of the howto ...This document describes how to install a mail server based on Postfix that is based on virtual users and domains, i.e. users and domains that are in a MySQL database. I'll also demonstrate the installation and configuration of Courier (Courier-POP3, Courier-IMAP), so that Courier can authenticate against the same MySQL database Postfix uses.
The resulting Postfix server is capable of SMTP-AUTH and TLS and quota (quota is not built into Postfix by default, I'll show how to patch your Postfix appropriately). Passwords are stored in encrypted form in the database (most documents I found were dealing with plain text passwords which is a security risk). In addition to that, this tutorial covers the installation of Amavisd, SpamAssassin and ClamAV so that emails will be scanned for spam and viruses. I will also show how to install SquirrelMail as a webmail interface so that users can read and send emails and change their passwords.
The advantage of such a "virtual" setup (virtual users and domains in a MySQL database) is that it is far more performant than a setup that is based on "real" system users. With this virtual setup your mail server can handle thousands of domains and users. Besides, it is easier to administrate because you only have to deal with the MySQL database when you add new users/domains or edit existing ones. No more postmap commands to create db files, no more reloading of Postfix, etc. For the administration of the MySQL database you can use web based tools like phpMyAdmin which will also be installed in this howto. The third advantage is that users have an email address as user name (instead of a user name + an email address) which is easier to understand and keep in mind.
This howto is meant as a practical guide; it does not cover the theoretical backgrounds. They are treated in a lot of other documents in the web.
This document comes without warranty of any kind! I want to say that this is not the only way of setting up such a system. There are many ways of achieving this goal but this is the way I take. I do not issue any guarantee that this will work for you!
