Vodacom Broadband Connect Fibre- Observatory Home Connect
Bushbug
Has anyone had experience of Vodacom Fibre to the Home ?
Is it stable ?
Does it get congested ?
Would you change from Telkom adsl to Vodacom Fibre ?:erm:
HavocXphere
Unless there is something seriously wrong with the offering (price / cap / flexibility) then fibre will always win. Its superior from a technical point of view so unless they screw you in some other way its a good bet.
The offerings might become congested at some point but right now its a premature question. Too early to tell really. Can't be that much worse than ADSL though imo...
And yes you should change, especially if you're OK with being locked into a 12/24 month contract. Its a gamble on that front...but personally I'd be inclined to jump on the first decent offering & aim for 12 month rather than 24. (or open access data if you can get that)
SFW007
you do realize that most are trying to lock you into a contact to recoup the cost of providing FTTH.
