From the Intellybox web site:
Most issues with the IntellyBox can be solved by rebooting the device
Really?
If the IntellyBox is left unused and still plugged in, it may auto power off. Simply remove the power cord when this happens and reinsert in order to reboot the device
Oops forgot to switch it off last night. Now let me try find which power cable it is behind the tv. Man, sometimes I miss load shedding.
The IntellyBox has 1GB of RAM has been designed to carry out one command at a time. If you click on several commands the IntellyBox will systematically work through each one and appear to be hanging. Either wait for each command to be executed or simply reboot the IntellyBox
Interesting. BTW this is the only place it mentions the RAM. No other specs are given other than its a quad-core (quad what is anyone's guess) and a few ports. And the site also explains how to side load DSTV and Netflix.
