Vodacom Speed Test & Results: speed.vodacom.co.za & speedtest.net
3g_rox
Attempt 1:
Below is the data used to calculate your download speed:
Download time: 12.11 seconds
Size of file: 500 KiloBytes
Estimated line speed: 336.9 (kilobits/second)
Estimated line speed: 41.3 (kiloBytes/second)
Attempt 2:
Download time: 12.328 seconds
Estimated line speed: 331 (kilobits/second)
Estimated line speed: 40.6 (kiloBytes/second)
Attempt 3:
Download time: 12.109 seconds
Novatel datacard on 3G in Durban
vodacom3g
Vodacom Representative
Carlhead said:
Yes, 3G isn't hard limited to 384k, I believe it is a high average that service is delivered at.
The 384Kb/s is actually a hard limit, dictated by the network equipment. If you see numbers exceeding 384 it's one of the following:
1) Inaccurate measurement by the OS based tools. Basically how the speed is measured is by a comms layer process that counts the number of bytes coming in. By taking a delta over a known time period (say a second), you can calculate the throughput. This works most of the time. Sometimes the period is shorter or longer and this skews the results.
The longer the measurement period (say 30 minutes) the more accurate the result, so watch out for funny looking spikes and discard them.
2) Caching by your PC. Check that the file you're downloading is not already cached. If so, the results will normally be completely wrong, as in TB/s!
3) Compression on the network. We do have this capability and with it on, I've seen >500Kb/s. Currently it's off.
Carlhead
Ok, my bad... wasn't aware that it was hard limited.
I suppose the speeds are pretty consistant though... The results of this thread indicate that you'll probably be running between 280k and 384k (If you've got semi decent cell signal). That's more than acceptable to me; now if we can only get the understandably high costs of bandwidth down!
nextstep
Not bad, but not all that good either (Olympus, Pta using 3G):
* Download time: 18.177 seconds
* Size of file: 500 KiloBytes
* Estimated line speed: 224.5 (kilobits/second)
* Estimated line speed: 27.5 (kiloBytes/second)
MrG
i have been travelling and coverage is very good. Speeds are ok for now aswell
MrG
What I dont get is this... Its suppose to be 384kbps limit. Yes, when I download a file I get about 30-40kb per second. So thats normal.
The second I launch getright, and do segmented downloading (4 segments) I get about 120kb per second.
Thats 1MB every 8.5 seconds.
How does that work, I thought 3G cant do that
bam1
Slow 3G
3G in Sandringham, Johannesburg
Test 1 : 15h46 Friday 6 Jan 06
Test Start Time : January 6, 2006, 3:46:35 pm
Test End Time : January 6, 2006, 3:46:51 pm
Download Time : 16.09 seconds
Size of file : 511423 KiloBytes
Estimated line speed : 248.27 (Kilobits/sec)
Estimated line speed : 31.03 (KiloBytes/sec)
Download time: 15.092 seconds
Estimated line speed: 270.3 (kilobits/second)
Estimated line speed: 33.1 (kiloBytes/second)
Test 2 : 15h52 Friday 6 Jan 06
Test Start Time : January 6, 2006, 3:52:54 pm
Test End Time : January 6, 2006, 3:53:16 pm
Download Time : 21.74 seconds
Estimated line speed : 183.80 (Kilobits/sec)
Estimated line speed : 22.97 (KiloBytes/sec)
Download time: 23.494 seconds
Estimated line speed: 173.7 (kilobits/second)
Estimated line speed: 21.3 (kiloBytes/second)
Test 3 : 16h43
Download time: 15.983 seconds
Estimated line speed: 255.3 (kilobits/second)
Estimated line speed: 31.3 (kiloBytes/second)
Test Start Time : January 6, 2006, 4:43:57 pm
Test End Time : January 6, 2006, 4:44:13 pm
Download Time : 16.60 seconds
Estimated line speed : 240.69 (Kilobits/sec)
Estimated line speed : 30.09 (KiloBytes/sec)
Test 4 : 16h53 6 Jan 06
Download time: 19.589 seconds
Estimated line speed: 208.3 (kilobits/second)
Estimated line speed: 25.5 (kiloBytes/second)
Test Start Time : January 6, 2006, 4:53:20 pm
Test End Time : January 6, 2006, 4:53:43 pm
Download Time : 22.20 seconds
Estimated line speed : 179.98 (Kilobits/sec)
Estimated line speed : 22.50 (KiloBytes/sec)
Test 5 : 17h42 6 Jan 06
Download time: 20.749 seconds
Estimated line speed: 196.6 (kilobits/second)
Estimated line speed: 24.1 (kiloBytes/second)
Test Start Time : January 6, 2006, 5:42:07 pm
Test End Time : January 6, 2006, 5:42:29 pm
Download Time : 22.82 seconds
Estimated line speed : 175.09 (Kilobits/sec)
Estimated line speed : 21.89 (KiloBytes/sec)
Vodacom3g has instigated an investigation as to why I am getting these below average speeds. Thanks Vodacom3g
Liposuck2004
Download time: 12.188 seconds
Estimated line speed: 334.8 (kilobits/second)
Estimated line speed: 41 (kiloBytes/second)
novatel 3g midrand
Lipo
Gazer
Download time: 14.125 seconds
Estimated line speed: 288.8 (kilobits/second)
Estimated line speed: 35.4 (kiloBytes/second)
Vodacom 3G Brackenhurst Aberton (although it seems I connect using GPRS mostly and keep losing my connection)
SoTrue
Attempt 1
Download time: 114.109 seconds
Estimated line speed: 35.8 (kilobits/second)
Estimated line speed: 4.4 (kiloBytes/second)
Attempt 2
Download time: 66.078 seconds
Estimated line speed: 61.7 (kilobits/second)
Estimated line speed: 7.6 (kiloBytes/second)
Attempt 3
Download time: 17.703 seconds
Estimated line speed: 230.5 (kilobits/second)
Estimated line speed: 28.2 (kiloBytes/second)
Attempt 4
Download time: 11.312 seconds
Estimated line speed: 360.7 (kilobits/second)
Estimated line speed: 44.2 (kiloBytes/second)
Attempt 5
Download time: 57.359 seconds
Estimated line speed: 71.1 (kilobits/second)
Estimated line speed: 8.7 (kiloBytes/second)
This is all within the hour (after 21:00 today), Mooikloof (Pretoria) tower, trying to use 3G on a SE V800, mostly falling back to GPRS. Extremely frustrating, sometimes I feel like throwing the cellphone against the wall. If only there was something else.....
MrG
Doing tests again for 2006....
Vodacom3G - 10:28PM - PM - Sonstraal Heights, Cape Town 3G Tower
Results: Opera Browser
Download time: 17.14 seconds
Estimated line speed: 238 (kilobits/second)
Estimated line speed: 29.2 (kiloBytes/second)
Results:
Download time: 9.125 seconds
Estimated line speed: 447.1 (kilobits/second)
Estimated line speed: 54.8 (kiloBytes/second)
Results:
Download time: 9.563 seconds
Estimated line speed: 426.6 (kilobits/second)
Estimated line speed: 52.3 (kiloBytes/second)
Results:
Download time: 9.75 seconds
Estimated line speed: 418.5 (kilobits/second)
Estimated line speed: 51.3 (kiloBytes/second)
Results:
Download time: 9.453 seconds
Estimated line speed: 431.6 (kilobits/second)
Estimated line speed: 52.9 (kiloBytes/second)
Results:
Download time: 9.187 seconds
Estimated line speed: 444.1 (kilobits/second)
Estimated line speed: 54.4 (kiloBytes/second)
Using: Nokia 6680
piranha786
Download time: 12.098 seconds
Estimated line speed: 337.2 (kilobits/second)
stellenbosch, seems nice, Will try MTN 2morrow
vodacom3g
Download time: 2.354 seconds
Estimated line speed: 1733.2 (kilobits/second)
Estimated line speed: 212.4 (kiloBytes/second)
Done in Midrand, last week Tuesday.
vodacom3g
Currently on the edge of 3G cell, getting 1 bar. So the HSDPA card has modulated down to still give connectivity. Had to force it to 3G with profile.
Download time: 7.399 seconds
Estimated line speed: 551.4 (kilobits/second)
Estimated line speed: 67. (kiloBytes/second)
In general I'm getting around 1.2Mb/s.
MrG
who is paying for this might I ask :)
nevermind..
instructions... open Kazaa >>>
Download the entire p2p network >> host it from your laptop and us GPRSers will download from you... should be enough bandwidth :)
I will buy you a couple 100 Terabyte Harddrives for you
ibanez
I'm using the Nozomi data card together with an LPDA-A0021 antenna.
Connected with 5 bar signal strength, EDGE (3 red LED flashes at a time):
Test 1
Results:
Download time: 54.5 seconds
Estimated line speed: 74.9 (kilobits/second)
Estimated line speed: 9.2 (kiloBytes/second)
Test 2
Results:
Download time: 41.344 seconds
Estimated line speed: 98.7 (kilobits/second)
Estimated line speed: 12.1 (kiloBytes/second)
Test 3
Results:
Download time: 50.515 seconds
Estimated line speed: 80.8 (kilobits/second)
Estimated line speed: 9.9 (kiloBytes/second)
Vodacom tower is Muldersvlei; assume this tower has EDGE enabled at a lower speed??
Help please, anyone..
vodacom3g
Vodacom Speed Test & Results: http://speed.vodacom.co.za/
Was playing with the new speed test TazzTux built (http://speed.vodacom.co.za) and noticed I'm getting extremely good throughput today. Not sure what the local guys did but I hope they won't stop. Pretty much hitting 1.75M peaks and consistently above 1.6M.
Check the attachments!
rpm
Admin
Staff member
Hi Vodacom3G
The results look impressive, but peaking at 2.02 Mbps?
Is this test only available to Vodacom IPs? Can not access it from ADSL…
Regards,
RPM
