Vodacom Speed Test & Results: speed.vodacom.co.za & speedtest.net
Somsteu
Got the following results on the voda speed site : location JHB CBD using a E220 modem and a 64k data sim (linked to my contract sim which is 3.6 enabled):
Down:614
Up:161:mad:
5 mins later:
Down:1007
Up:115
stable hsdpa connection with 3 bars
Can vodacom give us a map of the areas where 3.6 is properly operational i.e. where ther is sufficient backhaul.
vodacom3g
Vodacom Representative
Down:614
Up:161:mad:
5 mins later:
Down:1007
Up:115
As you know all the towers are on 3.6 but backhaul is in constant flux.
I confirmed again yesterday that there are many thousands of lines on back order. They are going in quite fast (we just seem to order faster than they can provide), so it will be near impossible to keen an accurate list.
I think the operational guys will shoot me if I add this onto their to-do lists :)
Is it just me or have you guys also noticed a slowdown in throughput over the last week?
Right after the launch we had many reports of ~2.5Mb/s but not anymore.
Would be good to do 3 tests:
1) speed.vodacom.co.za
2) speedtest.net to JHB
3) speedtest.net to CPT
I've been seeing better results on the off-net tests (speedtest.net) than on speed.vodacom.co.za which obviously should not be. Busy checking it out.
Iam3G
Indeed.
katvis
Panorama CPT:
Speed.vodacom.co.za 1933/345
speed.net to JHB 1910/340
speed.net to CPT 1130/110
Whats up with CPT?
kvi
ruimsig jhb
on hsdpa (yeah right)
speed.vodacom.co.za 907/264
vodacom3g
Panorama CPT:
Whats up with CPT?
This is a good case to discuss the effect the network architecture can have on test results and why it's not a good idea to do just one test (at one moment in time) before you accept the results.
As a starting point; it's obvious that the speed tests will download a file from a server, time this process and report it as average throughput over the download period. This is fine.
What you need to take into consideration is that you actually just measure the "slowest" element along the way. Think of a hosepipe, if you pinch it anywhere the total water flow is determined by the section that's pinched.
So anything from your PC to the Vodacom network to the non-Vodacom network (local and international internet links) to the remote server can be the bottle neck in determining maximum speed. International downloads typically shows this where the limit is the international links themselves.
It's still indicative of user experience though.
If you access the internet from the Vodacom network, you can break into the internet at a few points. These are determined by parameters like your location and APN.
So lets look at your results.
speed.vodacom.co.za was the fastest (we hope!). It sits on the Vodacom network in JHB, so if you're in CPT you still need to transverse the country-wide transmission network to get to it.
speedtest.net in CPT should give a better reading than JHB if you break out in CPT (using the internet APN in Western Cape). If it does not, it means the peering links from Cape Town to that ISP is congested or the test server itself is loaded.
If you broke out in JHB and CPT is slower, it again shows the peering links from SAIX down to that ISP is the most likely culprit.
Measuring speed in a dynamic network where load on any one of many elements can change instantaneously is nearly impossible. But taking a number of reading to different servers over time, will build up a picture. But even this 'picture' must be properly analysed before conclusions can be made. It's all part of Zen and the Art of Performance Management. :)
I've recently seen better result to speedtest.net than to speed.vodacom.co.za. So currently I don't fully trust the test and we're busy looking into it. I specifically think it starts under reading at around 2Mb/s.
A bit like the story of Van who got the job to test train wheels by hitting them with a hammer and listening to the sound. Cracked wheels made a dull sound and must be replaced.
Ol' Van had already decommissioned 50 trucks when they realised his hammer was cracked......
There are so many factors involved in doing these tests (links, servers, PC's, protocols, policies, etc.) that one should always carefully analyse the results. But it's very important to do these tests, so don't stop posting the results!
morkhans
A MyBroadband
Super Moderator
Seeing similar issues with the speedtest.net CPT server. speedtest.net is reporting my location as CPT. This is from Oxford street just off Wellington rd out in Durbanville.
speed.vodacom.co.za
Download Speed: 2297 kbps (287.1 KB/sec transfer rate)
Upload Speed: 259 kbps (32.4 KB/sec transfer rate)
speedtest.net - JHB
down: 1908 kb/s
up: 333 kb/s
ping 182ms
speedtest.net - CPT
down: 1009 kb/s
up: 114 kb/s
ping: 158ms
vodacom3g
speed.vodacom.co.za
speedtest.net - JHB
down: 1908 kb/s
up: 333 kb/s
ping 182ms
speedtest.net - CPT
down: 1009 kb/s
up: 114 kb/s
ping: 158ms
Which APN? Your current IP?
At least you can show ginggs the 1908 to JHB as prove that you must be in a 3.6 cell! :)
sand_man
speed.vodacom.co.za 2056/352
speed.net to jhb 1282/323
speed.net to ct 1040/301
speed.net to LA 787/254
smoking!!!!
vodacom3g
smoking!!!!
Internet APN?
You being in JHB but getting 1282 to the speedtest.net JHB server while morkhans got 1908 to the same server but from CPT, just highlights the points I made above about speed tests and how one should interpret them.
Notice how 'clean' the uploads are. Bodes well for UPA.
hermansteyn
My best speed test thus far:
Download Speed: 2552 kbps (319 KB/sec transfer rate)
Upload Speed: 348 kbps (43.5 KB/sec transfer rate)
kvi
well ive tried in various jhb locations, plenty hsdpa but no 3.6 for me. 155 says im upgraded yes, and ive got an E220. but the most ive ever seen is 1200kbps. (on any test)
am i missing something? E220 firmware upgrade?
SUPERMAN89
Vodacom speed in durban is great(i hope) but there's been alot of dc/cant connect/vpn apn dnt work/---:rolleyes:besides that haha its ok
kvi
my slow speed problem found...
ive been using E220 on leopard. leopard not supported with dashboard, so we got a jippo connection running it...
i moved the E220 to my hp laptop and .... varooooooommm.... 2600kbps :)
now to solve the leopard issue
vodacom3g
Our first MAC report, I think! :cool:
Have you tried the latest MAC dash?
Although 'officially' not supporting Leopard, we had reports here on the forum that it works fine on Leopard. Maybe try it.
Again your experience underscores the whole issue of maximising IT system performance.
Something, right from PC to the final server, can act as the bottleneck.
Best definition of Performance Management I ever heard; "PM is the detection and removal of a revolving set of bottlenecks." - Shaun Wormwald
As soon as you find the biggest bottleneck, the next one appears.
kvi
i dont know any leopard users that have managed to connect "with" the dashboard. i am connecting purely thru apples network settings..... it natively picks up the card
