K
kingrob
Guest
Is this test only available to Vodacom IPs? Can not access it from ADSL…
Regards,
RPM
I tried to access it, but it put my ol' iBurst modem in an infinite loop!
Regards,
RPM
Hi Vodacom3G
The results look impressive, but peaking at 2.02 Mbps?
Regards,
RPM
There is no requirement to make the site available from outside the VC network, so maybe the DNS (or routing) is not propagated.
Download Speed: 19019 kbps (2377.4 KB/sec transfer rate)
Upload Speed: 9265 kbps (1158.1 KB/sec transfer rate)
Please note the above readings are an indication of your current download and upload speed on the Vodacom network.
The scale on the meter indicates theoretical maximum download speed for each technology.
Actual results will vary depending on network load and radio conditions.
Upload Speeds:
Current upload speeds are up to 64Kb/s for 3G and up to 384Kb/s for HSDPA.
GPRS and Edge uploads are generally 25% of your current download speed due to handset limitations.
Results (Authentication needed)
You do realise I'll now get 22 PM's asking why they're not getting the same speed!![]()
But in the not too distant future you might see something like:
Download Speed: 6819 kbps (852.4 KB/sec transfer rate)
Upload Speed: 1265 kbps (158.1 KB/sec transfer rate)
Quite scary....but very![]()
Download Speed: 19190 kbps (2398.8 KB/sec transfer rate)
Upload Speed: 8645 kbps (1080.6 KB/sec transfer rate)
Is there an ip for this? Somehow it doesn't want to resolve on VM HSDPA.Was playing with the new speed test TazzTux built (http://speed.vodacom.co.za) and noticed I'm getting extremely good throughput today. Not sure what the local guys did but I hope they won't stop. Pretty much hitting 1.75M peaks and consistently above 1.6M.
Is there an ip for this? Somehow it doesn't want to resolve on VM HSDPA.![]()
Virgin...who ?
The test is for Vodacom IPs only :/
So if you're roaming on Vodacom with Virgin for data the connection is routed over the Virgin network and not Vodacom's at some point then? (Presuming he's roaming on Vodacom if he's using HSDPA)
