Moved to my room, seems to have improved(note sarcasm after seeing results):
Download Speed: 314 kbps (39.3 KB/sec transfer rate)
Upload Speed: 332 kbps (41.5 KB/sec transfer rate)
This started at about 5-ish at work, and this is what i got at home now:
Download Speed: 110 kbps (13.8 KB/sec transfer rate)
Upload Speed: 323 kbps (40.4 KB/sec transfer rate)
I'm not laughing...
You're knocking Vodacom so much lately, I asked the guys to limit your throughput so you can have something real to moan about.But only after hours.
Joking of course, but if you send me your data number...![]()
Just for interests sakes, i'm on Prepaid. I never switched on the HSDPA 3.6 Trial on my line. I used the 1.8 Profile up until the 29th of April 2008.
Went on leave, came back to this.
Well, there you go then. Don't take leave, you'll have plenty of time to rest when you kick the proverbial.
Do the 1 to 9 with the details of the area where you getting the crappy speeds and PM (or mail me). You'll find me on the GAL.
Well, decided to do a speed test from work using speed.vodacom.co.za. The MTN dash shows a signal strength of 2 bars (E620tool shows -85dbm), which is more or less the best signal I can get either at work or at home (using a Vodacom sim!).
Results:
Download speed: 1924 kbps
Upload speed: 301 kbps
Definitely not bad considering the signal.
The quality of your signal is obviously very good, despite the strength of it.
