Does anybody have more info regarding the antenna supplied with the Option HSDPA (nozomi) card?
I can't find any docs on the CD regarding the antenna.
If I insert the card and do an AT+CSQ, it reports 12,0 at my home. As soon as I insert the antenna in it's plug, I get 7,0 - to me this signal seems lower? I then stuck the antenna to an aerosol can, vertically, and rotated it in 45 degree intervals, each time I waited a bit then did the at+csq. The level is between 7,0 - 9,0 no more but as soon as I remove the antenna, it jumps back to 12,0. This just doesn't make sense to me and with no docs, I have no Idea how it is supposed to work.
The second issue I cannot find any info or docs on, is the status LED's. The staus LED info on the forum are not for the OPTION 3G hsdpa cards and I would love to know what they mean!
Here is the info of my card as reported by the ATI command in minicom.
Manufacturer: Option N.V.
Model: GlobeTrotter 3G+
Revision: 3.15.0Hd (Date: Feb 06 2006, Time: 12:53:15)
