Voip desktop and wireless phone on 1 connection
Ianf1
Can you connect a desktop voip phone and a wireless voip phone on one connection? Currently have a Fanvil X3sp phone and need to add a wireless / cordless phone, and want to know if we buy a wireless phone like this will it work with the desktop or do we buy a wireless setup with 2 phones.
Anyone have experience with doing this?
Rocket-Boy
Im assuming you have a single account to use with it?
Generally you can only sign into an account on one device at a time. So you can either get a second account for it or just use the dect phone as primary.
Ianf1
Thanks I will contact Switchtel and see what they advise.
Ianf1
OK feedback from Switchtel if you want cordless and desktop you need to switch to a cloud PABX which has a higher monthly subscription. So will look for a good deal on wireless with 2 handsets.
deweyzeph
If you want to run multiple phones on 1 SIP line, you should get a Raspberry PI and install a PABX system such as 3CX or FreePBX on it. Then you can setup each phone as an extension and have all sorts of rules, like which phones should ring if an incoming call comes in, transfer calls between phones, etc.
Ianf1
That is something to consider. I have ordered a single wireless phone from switchtel who will also configure it for us.
deweyzeph
This is actually something I've just done at home. I've 3 VOIP phones at home all connected to a Raspberry Pi running 3CX. I've got a single SIP account with Freshphone which I've setup as a SIP trunk in 3CX. When an incoming call comes in, I've set it up so that all 3 phones ring, and all 3 phones can make outgoing calls that go through the single SIP trunk. Plus, any phone can make an internal call to any other phone in the house without ever leaving my local network simply by dialing the internal extension number allocated to each phone. Works like a charm.
killerbyte
If you are interested in going the 3CX route then feel free to drop me a PM and I can assist you in setting up. I have my 3CX Advanced Certification and I really love the system.
BEAR11
Hi I have a desk VoIP phone at work and want a cordless headset as I'm not constantly at my desk to answer calls. Is there any kind of adaptor or something I can attach to the desk phone so that I can hook up a cordless one just so that I can carry it around with me on my operations floor.
BEAR11
Also FYI please use simple terms I'm not very technologically advanced
