Water meter - JHBWater - Northern JHB
Lateinlife
I have a strange situation at home and I hope someone can explain or assist - when measuring 5L of water in the kitchen my water meter outside clicks over 45L . There are NO leaks as the meter does not click over when no taps/toilet/washing is being used. JHBWater has been out and changed the meter with the same result - over reading the usage by 8-9X . Plumber and leak detection both confirm no leaks
Is this the norm? and no my house isn't haunted
ProfA
What did JHBwater say when they installed a new meter, then tested it to give the same over reading result??
Lateinlife
JW changed meter 2 x and both gave same result - i got a reply " thats the way it is "
Lateinlife
this was from the technical crew , please test yours and see if you get the same or different - very frustrating
ProfA
Will test mine after work and provide feedback. But I can already tell you, it is not acceptable if it does over read.
Lateinlife
anyone who reads this please test your water meter and see what the results are - I have the new raised meter with the blue lid
ProfA
No - analog meter - billed in arrears
OK. I am pre-paid with a digital meter connected to an analog meter. I can however only see the digital part telling me how many litres I have left. But will test nonetheless.
quovadis
Lol good luck with JW - Have a case with the Joburg Ombud for 6 months now despite a copy of a JW letter stating meter is faulty and should be replaced. They won't act at all. Ombud investigator is always on leave and always promising feedback but nothing else.
Lateinlife
Had a similar situation when I changed from the old meter buried in the ground. Eventually went to the mayor's office after 5months and got some action.
ProfA
Tested mine. 16373 litres was the start reading. Keep in mind I am on pre paid so the reading must come down. Filled a 5 litre water bottle to the brim and the reading afterwards was 16367 which is 1 litre out, but I think that is because of two reasons. Reading doesn't account for decimals and I used slightly over 5 litres as I filled the bottle to the brim.
Lateinlife
Thanks for the feedback , I will post pictures tomorrow of the start and end readings when filling 5L (over reads by by 8-10x) . My monthly consumption is about 15KL for a family of 4 (lucky i have a borehole for the garden) . The issue is the over reading of the meter which I never noticed till now . Can anyone test on a raised analog water meter ( measuring exact amounts of water )
Swa
It's suspicious that you say 10x. If you said something random like 27x I could believe it. Also your usage is normal so it's clearly not over reading.
