I have an IBurst UTD and I typically have it connected via ethernet port directly onto the PC (AMD running WinXP Home).
The issue is sometimes my IBurst connection crashes for no apparent reason. The UTD will still reflect the 5 green lights of connectivity however my internet connection will not send or receive any traffic. Furthermore when I try to disconnect my IBurst connection it freezes and won't disconnect until I reset my entire PC. Even then my Windows won't shut down because it can't shut down the IBurst connection so I have to manually power down the box.
I was just wondering if anybody else has experienced anything like this? and/or had any suggestions?
Thanks.
Thanks.
