Surely any 5V 2A power supply with the correct size connector would work?
Yikes turns out it's a 1A power supply in my B593, but anyway, I plugged a spare 2A one I have here and it works fine.
Are you sure that it is not 12V?
Surely any 12V 1A power supply with the correct size connector would work?
It's a 12V 1A power supply.
But where can I buy a spare one?
Chinese electronics shop?
Don't buy a cheap multi voltage PSU, those are typically unregulated crap.
If the spare 12/ 2A one you have fits and works, just use that...
Shame you're not in Cape Town, I literally have a largish box of spare power supplies i shipped over from my office in Shanghai one year, could have given you one.
12v/1A is pretty common though, I'm sure you'll find something else in the house.
You can also try Communica, ManTech or a similar supplier. CCTV voltages are the same, so any CCTV supplier will typically have PSU's for sale.
Where can I buy a replacement power supply for my Huawei B593 Router?
After some heavy lightning, the power supply got fried. Would like to get a new one, but have no idea who sells this on its own.
Any help will be appreciated.
^ This.You can also try Communica, ManTech or a similar supplier. CCTV voltages are the same, so any CCTV supplier will typically have PSU's for sale.
