Where to get 200mm chassis fan mounting screws?
dualmeister
Looking for eight of these in Cape Town. Any idea where?
Mounting screws typically used for 200mm chassis fan.
Nod
You could contact Wootware (Somerset West) and ask if they have.
Lupus
Im looking for those for 120mm fans, but cannot seem to find them. Cause the ones that came with Raidmax fans suck.
dualmeister
PS, trying to mount 140mm fans in front of Phanteks Enthoo Evolv ITX but screws not included :mad:
Tried some screws from Builders but no luck. Guess it will be cable ties.
dualmeister
In the past I have used standard M4 bolts with washers and nuts. Make sure to use a lock nut so that things don't work loose, e.g. https://www.builders.co.za/Fasteners-Fixtures-&-Security/Fasteners/Nuts/Eureka-4mm-Nylock-Nut-(30-Pack)/p/000000000000283177
Cable ties also work, although they can degrade in the long term. It will depend on how long you want to keep this for.
Thing is the holes are about 2.5mm and threaded. So the correct screw would be about 3mm with a fine thread. Tried every screw I have collected over more than a decade. Eventually bought some at Builders, but the thread just didn't match. Can't believe damn Phantek's claims it supports 140mm fans, but give no way of mounting them :mad:
Cooler Master on the other hand.
Fox1
Use a thinner and longer screw to get through the holes and put a nut at the end.
