Which is better option for growth Long Term
silkman
I have 2 quotes on the same unit trust (investing lump sum R200 000) for an elderly relative.
1) 1.5% upfront then 0.5‰ annually
2) no fees upfront then 0.65% annually.
Which one is best
TIA
3WA
Depends how long you're invested. Eventually option 2 will exceed option 1
Unless you really meant per mill in option 1, then it's really cheap.
Scooby_Doo
There would be a break-even point after which option 1 would be better. How long until they need it?
Edit.
Break-even is about 10 years. So if they need it in less than 10 years, go with 2, more than 10 years go with 1.
silkman
No - don't mean per mill
  • Like
Reactions: 3WA
Pegasus
Which one is best
TIA
Which Unit trust and which product? And is that the financial planners fee only?
silkman
It's an Oasis and Liberty product.
2 different ones.
Yes that's the planners fee
silkman
Wow
Thanks for that
What would happen on a 7% growth? I assume option 2 would be worse then
Pegasus
Wow
Thanks for that
Just doing a simple annual growth not compounded daily.
Formulas if you want to check
