Which prepaid for smart phone?
alternate
Cell C. Just buy a prepaid sim and test it if your'e worried about coverage.
AlmightyBender
Cell C. Do the test sim as above, but if you're in any form of city you will most likely be just fine
Dups!
Yep, Cell C is the best option. Their only problem is coverage, especially outside cities. Of course you will be able to roam on Vodacom but only in 2G.
D1RTY D4WG
With Cellc's new data prices I no longer feel the pinch of mobile data, it's so refreshing.
cavedog
If its cheap data you are looking for I could suggest something like a loophole with 8ta.
Activate the full blackberry bis on a prepaid simcard for R59. Doing so you will get a 500MB monthly bundle activated that you can use for anything. :)
Icemanbrfc
Many people are now moving away from voice packages, and going data packages. Might not work for many, but there you go
