Ballpark guesstimate might be 0.5 to 2l per hour. Depends on multiple factors such as air temperature and relative humidity (or dew point), thermostat setting, closed or open cycle ventilation, unit power, and many other factors...
No chemicals. It's just condensate. Just boil it to kill any bacteria before you drink it. Why do you want to put a tap on something that you want to drain? That's like putting a tap on your geysers overflow.Just curious here? Isn't water from the aircon unit loaded with chemicals ? Won't it taste weird from all the chemicals?
Otherwise wouldn't aircons come with a tap? If it was that safe to drink?
It can be used for the toilet or hand washing(unless you have one of those old top load machines like my gran use to have)Just curious here? Isn't water from the aircon unit loaded with chemicals ? Won't it taste weird from all the chemicals?
As mentioned in the thread already linked, I collect about 25l per day. I only have my aircon for a couple of weeks and started collecting last week.
On the dehumidifying setting i managed 50l in a 24hr period. I have 4 x 25l drums I'm collecting them in. My water had been off for the past 2 days due to a burst pipe and the water from the aircon has been a lifesaver.
Aircon is from House & Home 12 000 BTU.
Some pics below.
The three glasses are, from left to right, tap water, bottled water and condensate from my aircon.
Edit: Link https://mybroadband.co.za/vb/showthread.php/932781-Water-from-Air
Yoh, that's pretty damn good. Any idea what this is costing in terms of electricity?
I very much doubt that the materials used in an air conditioner are safe for humans. Now, this probably isn't a problem since the water isn't sitting inside the aircon for extended periods like with plastic bottles, but it is something to be aware of.
What makes it unsafe?
Its full of dust, probably Legionella bacteria, heavy metals from motor vehicle exhaust, etc. Unless you clean and sterilise the condensation drip tray, treat like any rain-water or grey-water resource.
12000 BTU newly installed York aircon gives us only a trickle and wife uses it from 08:00 - 17:30 each day set at 23C. Unit is too efficient![]()
