Wi Fi Problems
Vercogen
I recently got wi fi, with some problems i might add.
Peer to peer programs didn't seem to work as well as Guild Wars and a couple of other programs using the net.
So i got Wingate. Its working but with some problems
Is there a better program than Wingate on the market?
skydog
I'm not with you.
what does wingate and wifi have to do with each other?
what are you using wingate for?
bwana
MyBroadband
Super Moderator
Yeah - wingate?
What wifi hardware do you have?
Vercogen
bwana v.14 said:
Yeah - wingate?
I'm a bit of a noob here soz
My hardware consist of a dish and a network cable plugged into a adapter and then going to my pc.
Vercogen
skydog said:
I'm not with you.
I can for example not connect to guild wars exept when i add the exe file to wingate?
like i said nOOB but thats why im asking an that's why i started the thread
mic_y
At fist guess I would say that you need to set up port forwarding on your router. if you tell me what model you using, i could give u some more "detailed" instructions.
skydog
ok lets give this a go. just cant really help with the little info you he provided.
do you connect to a Wireless ISP?
can you be a bit more specific with the setup.
do you have a wireless card in your PC then a black cable running to a funny grey thing in the dish on your roof?
i'm guessing that wingate is your proxy/firewall software.
do you use more then one computer on your network that connects via the wingate?
