Hi guys,
I am experiencing the following problem. On Friday, a client calls me, and says that the internet on one machine is not working. I go out to their office to check up on what the issue is, and see that the machine is connected to the wireless network, but the connection is just at the physical level. To explain this, if I right-click on the wireless connection, and click status, it gives me the following:
IPv4: Not Connected
IPv6: Not Connected
Media state: Enabled
Duration: ...
Speed: 54mbps
And so on and so forth.
If I click on the details button (where all the IP's and so on would normally be listed), I was greeted with a completely blank form. By blank, I mean that even the property column contained absolutely no values what so ever.
Now, I tried reinstalling driver, etc, etc, but no luck.
Eventually, I gave up and decided to take the machine in to just back it up, reinstall Windows (Win 7 Pro - 64 Bit) and go from there.
Got it home, tried with another wireless card (just to make sure that it wasn't the hardware) and still the same result. Took my removable drive, backed up all the data from the clients machine, and started reinstalling windows.
While this was happening, I needed something off the removable, so I plugged it into my machine. Then shut it down, to reinsert the WiFi card that I had taken out.
Upon rebooting, I was greeted with the same problem as I had been experiencing on the client machine, except this time, with my Wired network connection.
Any ideas on what this could be?
IPv4: Not Connected
IPv6: Not Connected
Duration: ...
Speed: 54mbps
