superfantasties
- Feb 7, 2010
Recently got into gaming again, new pc but still play on a non widescreen monitor. It's actually a 5:4 monitor, not even 4:3 (so it's even more square shaped).
Almost every game I play everything looks very zoomed in, it's making quite nauseous. Worst offenders are fps games. In Half Life 2 I had to go into the console to change my FOV to 106 degrees, this made it perfect.
I've just started Battlefield 3 however and even though there is a FOV slider in the menu it only goes up to 90 degrees, which is not enough, it still has that zoomed in look. So my question is: is it my monitor causing this? Will 90 degrees on a widescreen 16:9 monitor look right? (whereas it still looks zoomed in on my 5:4 monitor)
