antowan
- Nov 1, 2003
I setup a WDS configuration of Ubiquiti Picostations 2. About 5 of them.
The setup was reliable until revamp and now there is a LAN cable to the other side of the house making setup easier.
I am curious however to hear what you would do with a situation like this assuming NO LAN cable and the impossibility of installing one esthetically.
Thus your challenge is thus. Install wifi that is accessible everywhere in the house. Walls are about 4 bricks thick with steel reinforcement and you have about 6 of them in your way from one side of the house to the other. The house is about square but the ADSL connection is in the bedroom on the upper level on one side of the house. The distance from one side to the other is about 120m. The floor between levels is also concrete with steel reinforcement.
Data over powerline is not really viable and esthetically a no go. Too many distribution boxes.
What would you have done and used. Be specific with reasons if you please.
