word problem
killadoob
excel opens rwally fast
but when i open word it opens really slow and tell me running virus scan
when i open word docs it does the same?
how do i turn this off?
i do not have norton i use avg
zerofocus
Start -> Run -> regsvr32.exe /u avgoff2k.dll
This will disable the office plugin.
killadoob
yea well i have removed it i have turned the plugin off
all that happens is word does the same thing just doesnt say running virus scan grrrrrrrr
zerofocus
Try this....
Start -> Run -> winword /a
This will run word in a safe mode. If this works you know there is some plugin that is screwing around. Let me know if it does so i can tell you what to check next.
killadoob
okie dokie
i just removed office deleted all the registry keys
removed avg all registry keys
gonna reload off now see if it works
zerofocus
Good luck. It just sucks when a software package you paid R3.50 for doesnt work :D
killadoob
you know whats so funny
this is an orignal 2000 rand package
the package i download for the cost of the bandwidth ive never had a days problem with
strange i think
killadoob
zero dude that winword a opens super fast
clcik on word icon takes forever?
why?
zerofocus
Some would say you are being punished. I dont say anything cause im scared bubba likes pale white ass ;)
killadoob
so what else can i try i have to have this lady's laptop back tomorrow?
killadoob
ahhhhhhhhhhhhhhhhhh yes i found a site that fixed the problem
normal.dot was corrupt change the name and word creates a new one that opens fast
thanks for trying zero
zerofocus
Try opening a word document. If it opens straight away, then your normal.dot file might be corrupt.
zerofocus
Oh, and im pretty sure it might be some plugin. Check for other applications on the system that might have office plug-ins.
zerofocus
I think i found the dir i was looking for....
C:\Program Files\Microsoft Office\OFFICE11\STARTUP
check if theres anything in there, if there is move them to another folder. and try again. Yours might be office10 or office9 depending on your version
