Would a Gb 24-port switch be better able to handle more than a Gb 8-port switch?
PostmanPot
Good morning all.
Might be a silly question.
Scenario is that a company's server is connected to an 8-port switch to provide LAN, WLAN, ADSL, etc. to quite a few people. So the 8-port is handling quite a bit of stuff.
They're reporting that wireless connections are always dropping. One of the IT guys there thinks it's because the 8-port switch isn't able to handle everything being thrown at it? :confused: He reckons a 24-port would handle things better because it's bigger? Even though not more than 8 ports would be used on the 24-port switch.
In my limited networking experience, I don't think that it's the 8-port acting up, and that it's something else along the lines acting up. But of course I could be wrong.
I was hoping for some advice here. :)
8-port is a D-Link GigaExpress DGS-1008D 8 port 10/100/1000 gigabit un-managed switch - auto-MDI/MDIX , 8k MAC address , 256k ram buffer per device
24-port they'd upgrade to would be a D-Link GigaExpress DGS-1024D 24 port 10/100/1000 gigabit un-managed layer2 switch - auto-MDI/MDIX , 8k MAC address , 512k ram buffer per device , rackmount ready
Could the increased buffer of the 24-port help?
TIA!
syntax
i seriously doubt the 24 port switch will make a difference.
PostmanPot
Me too. But the 24-port does have more buffer. What would that mean, gurus? :)
MickZA
The buffers reduce the chance of dropping packets, if you're not dropping any at the moment don't worry about it.
ponder
Wireless dropping the connection is not related to the switch I would say. Check the AP logs, if the wired LAN side does not have issues then it's not the switch.
Conradl
A switch has a fabric that can process packets at a certain rate. This means that while you may have 8 ports, and each port can handle 1GB, the fabric (the part that connects all the ports), may only work at 4GB; i.e. all the ports will be unable to run at full speed, since the fabric runs out of capacity. Moving from 8 - 24 ports increases the fabric capacity.
RAM buffers are used to buffer incoming data and prevent the switch from dropping packets. Assume that you had 7 machines (each 1GB) connecting to a server of also 1GB - the server port would be overloaded if each device was transmitting at 100%.
Having said that, four 15k SAS disks, will run a file server 1GB network at around 100% - assuming a sustained file copy via iSCSI to local disk. Running 8 regular machines, on a simple network, will simply not be able to generate enough traffic to stress the switch and cause it to drop packets. If you were to replace the switch , and it fixed the problem, then it would be a faulty switch and not overloading....
