Hi All,
Just a quick hello. Thought I'd call in about the titled 'Dialer Virus' that's kicking out connections in SA at the moment. (This also will give a 631 Error code on 3G)
If you check your network connections dashboard, if the malware is present you will have an extra network connection that does not make sense to you... This is your malware that hijacks your connection and kicks your default dialer off.
I have researched this one and it seems there is not a ready solution available, as it has even broached M-Web's server. If there are any of you who are experiencing complete deletion problems of this dialer malware, let me know as I have the script to remove it (It has the remarkable ability to regenerate, even when attacked for deletion in the registry.)
Its modus operandi leaves a file called aaw2.exe (or variants) in the documents root, and regenerates even if system restore is deactivated.
Mosts infectees have just disabled it by pulling its arms and legs off, but its presence can be annoying.
If I am mistaken about its abundance, then little response will validate a removal of this thread. In the meantime, this contribution may well be of help to those who are experiencing extreme frustration.
Cheers
Cheers
