• You are not registered on MyBroadband, which means you miss out on great benefits. To join our community is very easy, and completely free. Register now.
  • New Two-Day Giveaway - Enter Here
Zalman HD 501 parts
adielk
#1
I am looking for the screws/bolts of the rear panel for the top panel of the zalman hd501 htpc case.
These are the type where you dont need a screw driver.
Where can I purchase some as Zalman does not support the case anymore and provided no alternative.
I am sure one can use ones from other cases but dont the specs and dont know where to purchase just the screws/bolts
ponder
#2
Just use normal pc case screws or thumb screws. Try any pc shop or look in your drawers.
adielk
#3
Matrix told me they dont sell. I must get it off an old pc.
Thanks think its "thumb" screws.
Will check around at smaller pc shops.
adielk
#7
Helpful bunch, they probably have hundreds lying in the back in their screw stash.
Indeed popped into Matrix store for air to dust off my gpu. Saw new guy in store and when I asked him he gave me 2 screws. Slightly mismatched ones but hopefully in future Ill get matching one/s.
And yes had a box full of screws to choose from..
