South Africa’s new plug standard is mandatory – what you should know
At the beginning of the year, an amendment to South Africa’s wiring code came into effect which makes a new plug and socket standard, SANS 164–2, mandatory for new installations.
SANS 164–2, also known as ZA Plug, has the same hexagonal profile as the Europlug seen on cellphone chargers, but includes an earth pin.
It is substantially more compact than South Africa’s three-prong plug standard, and has much thinner pins.
With the wiring code amendment taking effect in January 2018, each plug point in a new building must have at least one socket that can accommodate a ZA Plug.
However, uptake of the plug standard has been slow for several reasons.
South Africa's new plug standard
ZA Plug uptake
Cecil Lancaster, a regional director for the Electrical Contractors’ Association of South Africa ECA(SA), said that from the installer’s side there was initially some confusion about the wiring code requirements.
There was also some initial resistance due to the price difference between installing an outlet with at least one ZA Plug socket in it, and outlets that only support the older standard.
The price has since reduced to the point where it is no longer a factor, said Lancaster.
A natural knee-jerk resistance to change has also been a factor, he said.
“There was some consumer resistance due to existing appliances bearing the old type plug, but it is mostly satisfied by offering combination socket outlets containing both types,” he said.
On whether manufacturers have been supporting the standard, Lancaster said that most consumer goods have been coming with compatible plugs for some time.
“Think phone chargers, audio-visual equipment, TVs, DVD players, decoders, kitchen appliances, and similar unearthed appliances,” he said.
“Earthed and more energy-intensive appliances like kettles, washing machines, fridges and such are slower taking it up.”
Chicken and egg
Lancaster said that it remains a chicken-and-egg situation, however, as the installation of outlets increases, appliances will follow. Conversely, as more appliances come equipped with new plugs, it will stimulate the need for outlets.
One obstacle to the transition is that socket-outlet units seem freely available in the retail market, but plugtops less so.
To help reduce resistance to the change and further improve uptake, Lancaster said that “reverse adaptors” may be considered.
These would make it possible to plug equipment with old type plugs (164–1) into an adaptor which fits into a new socket (164–2).
“Such adaptors are currently frowned upon by the powers-that-be because it was seen as a manner of circumventing or slowing down the transition,” said Lancaster.
Why a new standard?
When the IEC first began development on IEC–906–1, which became IEC60906–1, it was trying to establish a universal plug and socket system.
Despite its efforts, commercial and political interests caused the standardisation initiative to fail in Europe. Brazil and South Africa are the only countries to have adopted the standard.
However, Brazil deviated from the standard by delivering either 127V or 220V mains using the same socket.
Japan and the US have plugs and sockets that are compatible with the IEC’s envisioned global standard for 125V sockets.
Talk of adopting the new standard began in South Africa in 1993, and a version of SANS 164–2 that dates back to 2006 is available online.
According to the SABS, the ZA Plug appeared in South Africa’s wiring code (SANS 10142–1) during 2012.
Old standard still legal
Although it is now required to integrate sockets which comply with the ZA Plug standard in new buildings, the old standard remains legal.
As Lancaster mentioned, combination outlets are available which include the old SANS 164–1 socket, as well as ZA Plug sockets.
So long as an outlet includes at least one ZA Plug socket, it complies with the wiring code requirements.
The wiring code amendment also does not affect existing buildings, including homes.
It is therefore not currently necessary for South Africans to switch the existing electrical sockets in their homes.
Now read: New South African plug standard – 6 reasons it is better than our old plugs
Partner Content
Recommended
Share this article
