Eskom warns of increased load-shedding — as South Africans suffer through Stage 6
Eskom has issued a warning for the possibility of higher stages of load-shedding due to cold weather and is urging South Africans to switch off non-essential appliances during the evenings.
This comes as the country is already in continuous stage 6 load-shedding — the highest level implemented so far this year — until further notice.
“Due to the cold weather, we appeal to all members of the public to reduce the electricity demand between 17:00 and 21:00, by switching off non-essential appliances, mainly geysers, swimming pool pumps and electric heaters,” said Eskom.
“The evening peak forecast for today is 29,609MW and yesterday’s [Tuesday, 12 September 2023] demand at evening peak was 33,423MW, higher than the forecast demand.”
“The reduction will continue to assist in alleviating pressure on the system and avoid higher stages of load-shedding,” it added.
The demand recorded on Tuesday was close to the peaks seen during the coldest nights of the winter this year.
Higher levels of load-shedding already reached
Eskom has yet to officially announce the implementation of load-shedding higher than stage 6.
According to Eskom’s own website, one stage of load-shedding is equivalent to up to 1,000MW being shed from the grid.
Stage 6, therefore, only allows for up to 6,000MW of capacity to be shed from the grid.
However, the power utility’s historic peak evening statistics revealed that it shed well over 6,000MW from the grid on multiple occasions in the past few years.
For example, on 21 February and 22 February 2023, Eskom shed demand of 7,045MW and 7,092MW, respectively.
By Eskom’s own definitions, that would technically have been stage 8.
Then-Eskom spokesperson Sikonathi Mantshantsha acknowledged it was “accurate to say at that particular…, load-shedding was Stage 7“.
Energy analyst Chris Yelland agreed with Mantshantsha’s take, while former Eskom CEO Jacob Maroga said it was actually stage 8.
However, Eskom’s former head of generation, Thomas Conradie, denied implementing stage 7 load-shedding or higher.
More recently, National Rationalised Specifications (NRS) Association of South Africa chairman Vally Padayachee revealed that the true definition of load-shedding stages is more complicated than Eskom has let on.
He explained that one stage of load-shedding could vary between 800MW and 1,200MW being cut from the grid.
The table below shows the discrepancy between Eskom’s declared load-shedding stage and what stage of load-shedding would actually have been in effect had the utility followed its own rules.
Date Load-shedding Reported Stage Defined Stage
Thu, 1 June 6,684 MW Stage 6 Stage 7
Fri, 2 June 3,967 MW Stage 4 Stage 4
Sat, 3 June 3,978 MW Stage 4 Stage 4
Sun, 4 June 2,042 MW Stage 2 Stage 3
Mon, 5 June 4,553 MW Stage 4 Stage 5
Tue, 6 June 3,271 MW Stage 3 Stage 4
Wed, 7 June 3,136 MW Stage 3 Stage 4
Thu, 8 June 2,939 MW Stage 3 Stage 3
Fri, 9 June 3,060 MW Stage 3 Stage 4
Sat, 10 June 4,091 MW Stage 4 Stage 5
Sun, 11 June 3,905 MW Stage 4 Stage 4
Mon, 12 June 3,146 MW Stage 3 Stage 4
Tue, 13 June 3,252 MW Stage 3 Stage 4
Wed, 14 June 3,123 MW Stage 3 Stage 4
Thu, 15 June 2,949 MW Stage 3 Stage 3
Fri, 16 June 2,912 MW Stage 3 Stage 3
Sat, 17 June 3,000 MW Stage 3 Stage 3
Sun, 18 June 3,052 MW Stage 3 Stage 4
Mon, 19 June 3,161 MW Stage 3 Stage 4
Tue, 20 June 3,302 MW Stage 3 Stage 4
Wed, 21 June 3,397 MW Stage 3 Stage 4
Thu, 22 June 3,258 MW Stage 3 Stage 4
Fri, 23 June 3,041 MW Stage 3 Stage 4
Sat, 24 June 3,044 MW Stage 3 Stage 4
Sun, 25 June 3,108 MW Stage 3 Stage 4
Mon, 26 June 3,287 MW Stage 3 Stage 4
Tue, 27 June 3,218 MW Stage 3 Stage 4
Wed, 28 June 3,281 MW Stage 3 Stage 4
Thu, 29 June 3,121 MW Stage 3 Stage 4
Fri, 30 June 3,076 MW Stage 3 Stage 4
Sat, 1 July 3,032 MW Stage 3 Stage 4
Sun, 2 July 3,184 MW Stage 3 Stage 4
Mon, 3 July 3,379 MW Stage 3 Stage 4
Tue, 4 July 3,276 MW Stage 3 Stage 4
Wed, 5 July 3,454MW Stage 3 Stage 4
Thu, 6 July 3,369 MW Stage 3 Stage 4
Fri, 7 July 2,795 MW Stage 3 Stage 3
Sat, 8 July 2,708 MW Stage 3 Stage 3
Sun, 9 July 3,054 MW Stage 3 Stage 4
Mon, 10 July 3,771 MW Stage 4 Stage 4
Tue, 11 July 4,082 MW Stage 4 Stage 5
Wed, 12 July 6,432 MW Stage 6 Stage 7
Thu, 13 July 6,929MW Stage 6 Stage 7
Fri, 14 July 6,416 MW Stage 6 Stage 7
Sat, 15 July 6,293 MW Stage 6 Stage 7
Sun, 16 July 4,234 MW Stage 4 Stage 5
Mon, 17 July 4,616 MW Stage 4 Stage 5
Tue, 18 July 3,198 MW Stage 3 Stage 4
Wed, 19 July 4,203 MW Stage 4 Stage 5
Thu, 20 July 4,312 MW Stage 4 Stage 5
Fri, 21 July 5,272 MW Stage 5 Stage 6
Sat, 22 July 4,199 MW Stage 4 Stage 5
Now read: Hawks acknowledge De Ruyter’s allegations against senior politicians — launch investigation
Partner Content
Recommended
Share this article
