Hard drive reliability: Seagate vs HGST vs Toshiba vs WD
Backblaze, an online backup provider, has published its hard drive reliability statistics for Q2 2016, which reveal the reliability of different hard drive brands and models.
The company bases its statistics on the drives it uses to store customer data for its online backup business.
At end of Q2 2016, Backblaze had 68,813 hard drives under its management in its data centre.
Backblaze calculated the annualised drive failure rate for each drive model. This is based on data from April 2013 through June 2016.
Annualised Hard Drive Failure Rates
Cumulative from April 2013 to June 2016
MFG Model Size Drive Days Failures Annualised Failure Rate
HGST HDS722020ALA330 2TB 5 145 341 226 1.60%
HGST HDS5C3030ALA630 3TB 5 125 937 115 0.80%
HGST HDS723030ALA640 3TB 1 135 729 57 1.80%
HGST HMS5C4040ALE640 4TB 2 906 904 78 0.98%
HGST HMS5C4040BLE640 4TB 2 683 029 30 0.40%
HGST HDS5C4040ALE630 4TB 2 906 904 78 0.98%
HGST HUH728080ALE600 8TB 22 858 2 3.20%
Seagate ST4000DM000 4TB 16 688 047 1 296 2.80%
Seagate ST4000DX000 4TB 203 976 25 4.50%
Seagate ST6000DX000 6TB 863 584 32 1.40%
Seagate ST8000DM002 8TB 44 000 4 3.30%
Toshiba DT01ACA300 3TB 56 191 7 4.50%
Toshiba MD04ABA400V 4TB 62 692 3 1.70%
Toshiba MD04ABA500V 5TB 21 915 2 3.30%
WDC WD20EFRX 2TB 60 963 15 9.00%
WDC WD30EFRX 3TB 834 697 150 6.60%
WDC WD40EFRX 4TB 38 404 3 2.90%
WDC WD60EFRX 6TB 259 381 35 4.90%
Average annualised drive failure rate per brand
The graph below shows the average annualised hard drive failure rate per brand.
Failure rate
More on hard drives
Samsung’s R140,000 SSD
Selecting a hard drive: SSD vs HDD
Best and worst hard drives revealed
Partner Content
Recommended
Share this article
