Hardware1.02.2011
Intel identifies chipset design error, implementing solution
In some cases, the Serial-ATA (SATA) ports within the chipsets may degrade over time, potentially impacting the performance or functionality of SATA-linked devices such as hard disk drives and DVD-drives.
The chipset is utilised in PCs with Intel’s latest Second Generation Intel Core processors, code-named Sandy Bridge. Intel has stopped shipment of the affected support chip from its factories, corrected the design issue, and has begun manufacturing a new version of the support chip which will resolve the issue.
The Sandy Bridge microprocessor is unaffected and no other products are affected by this issue.
The company expects to begin delivering the updated version of the chipset to customers in late February and expects full volume recovery in April.
For computer makers and other Intel customers that have bought potentially affected chipsets or systems, Intel will work with its OEM partners to accept the return of the affected chipsets, and plans to support modifications or replacements needed on motherboards or systems.
The only systems sold to an end customer potentially impacted are Second Generation Core i5 and Core i7 quad core based systems. Intel believes that consumers can continue to use their systems with confidence, while working with their computer manufacturer for a permanent solution.
Intel identifies chipset design error, implementing solution << Comments and views
Which printer brand do you trust the most?
