Hardware6.11.2007
Outdoor antenna from Poynting
Poynting says that protection against static-build-up and lightning is addressed by an integrated DC short in the antenna, and an additional earthing lug is provided that aims to allow the optional grounding of internal electronics to external structures, such as the mounting mast.
The WLAN-A0042 is additionally equipped with Poynting’s waterproof Ethernet cable gland, which is designed to allow direct, watertight connection of RJ-45-terminated CAT5 cable to the exterior of the enclosure for easy installation.
Unlike other Ethernet glands, this gland has been specifically designed for high UV-levels and is moulded in ultra-strong glass-reinforced nylon and provided with a tightening spanner, the company says.
Like all BridgePoynt enclosures, the WLAN-A0042 is provided with a mast-mounting bracket with continuous elevation tilt capability and a mounting kit for any type of electronics to be secured inside the enclosure, Poynting adds.
Comments
Which cryptocurrency exchange do you use?
