MSI has revealed its new GeForce GTX 1080 Ti Lightning Z graphics card, aimed at high-end gamers.
The card features a triple-fan cooler design and three preset clock speed profiles – Silent, Gaming, and Lighting.
These dynamically adjust GPU clock speed and memory frequency.
The card’s cooler sports customisable accent colours, and both the cooler and backplate feature RGB lighting zones.
MSI bundles its Afterburner overclocking software with the card, and the card sports an LN2 switch for extreme overclockers using liquid nitrogen.
No pricing is currently available.
MSI GeForce GTX 1080 Ti Lightning Z
| GPU | GP102-350 |
| CUDA Cores | 3,584 |
| Clock Speed | 1,721MHz / 1,607MHz (Lightning Mode). 1,695MHz / 1,582MHz (Gaming Mode). 1,582MHz / 1,480MHz (Silent Mode) |
| Memory | 11GB GDDR5X |
| Memory Frequency | 11,124MHz (Lightning / Gaming Mode). 11,016MHz (Silent mode) |
| Memory Interface | 352-bit |
| I/O | 2x DisplayPort 1.4, 2x HDMI 2.0b, 1x DVI-D |
| TDP | 250W |
| Power Connectors | 3x 8-pin |
| Dimensions | 320 x 140 x 61 mm |
| Weight | 1.7kg |
Join the conversation Autoload comments
Comments section policy: MyBroadband has a new article comments policy which aims to encourage constructive discussions. To get your comments published, make sure it is civil and adds value to the discussion.
