Transcend introduces 4GB extreme performance memory kit
Transcend Information, a global supplier of high performance memory modules, has unveiled its latest memory product – a 4GB aXeRam Extreme Performance DDR2-1066+ dual-channel memory kit that is designed to use only top-binned, premium quality DRAM chips and custom-polished aluminium heat sinks.
The kit includes a matching pair of 1066MHz tested and verified 2GB DDR2-1066+ modules which are intended to provide dual-channel memory bandwidth of up to 17GBps.
The 240-pin unbuffered DIMMs included in the kit are each made of 16 high-quality 128Mx8 DDR2 DRAM chips. Each chip is manufactured using small Fine-Pitch Ball Grid Array (FBGA) packages, aiming to ensure better thermal dissipation, electrical efficiency and improved over-clocking performance.
Transcend’s aXeRam DDR2-1066+ memory includes Enhanced Performance Profiles (EPP), which are designed to allow users to automatically configure EPP-enabled motherboards with aggressive memory settings for better memory and system performance, especially when using dual video cards.
