Presented by DrayTek
DSL or Fibre – why choose?
Life is full of choices. East or West? Capped or Uncapped? LED or Plasma? But most importantly – DSL or fibre?
Why not have both, with DrayTek’s brand new Vigor2862 series routers.
Featuring a DSL port, Ethernet WAN port for fibre CPE’s, 2 USB ports for 3G/LTE dongles and 4 gigabit LAN ports, you need not look any further for the ultimate load-balancing firewall router.
While many WiFi networks struggle to keep up with high-speed fibre internet connections, the Vigor2862ac’s 4 antennas coupled with an 802.11ac Wave 2 radio make light work of even the fastest wireless requirements.
Add into the mix: 32 simultaneous VPN tunnels, an SPI firewall with optional Web Content Filtering and free dynamic DNS hostname, and it becomes clear to see that the Vigor2862ac is the most comprehensive all-rounder for any home or SMB network.
Vigor2862 series specifications:
  • VDSL2/ADSL2+ Router
  • 1 Ethernet WAN (Load Balancing or Failover)
  • 2 USB ports for 3G/4G modem (Load Balancing or Failover) or extra storage
  • 802.11ac Wave 2 dual-band wireless for speeds up to 1.7Gbps (ac/Vac model)
  • 2 FXS ports (Vac model)
  • 32 Simultaneous VPN Tunnels (SSL/IPsec/L2TP/PPTP)
  • SPI Firewall with Web Content Filtering
  • Central Management for DrayTek WiFi Access Points and Switches
Click here to find the Vigor2862 that best suits your needs here.
For more information about DrayTek networking, contact SD Group on 0213001330, [email protected] or visit us at www.sdgroup.co.za.
This article was published in partnership with DrayTek.
Partner Content
Recommended
Share this article
