Presented by Samsung
How to work from home like a pro with Samsung DeX
Due to the national lockdown to curb the spread of COVID-19, many South Africans are now working from home.
Fortunately, the transition can be an easy one for professionals whose Samsung smartphone is an indispensable tool for their work.
Samsung smartphone and tablet owners have the advantage of their devices being compatible with the company’s cutting-edge DeX devices and software.
DeX allows you to link your smartphone or tablet to your PC or an HDMI-compatible display, empowering you to use applications and navigate through your smartphone’s interface like you would on a laptop or desktop computer.
Powerful applications
Using Samsung DeX is as easy as using a normal PC – the software supports multiple windows, a fully-featured desktop interface, keyboard and mouse support, and a suite of powerful applications.
Whether you need to edit photos or answer emails, DeX allows you to work efficiently on your smartphone.
Thanks to its Microsoft Office support, you can also create and edit Excel, PowerPoint, Word files, and much more, saving them directly to your Samsung device.
DeX also boasts support for Adobe Photoshop, Outlook, Skype, and OneNote.
Additionally, artists and graphic designers can benefit from pairing Samsung’s Galaxy Note 10 with DeX, as you can use the smartphone’s S-Pen to sketch out a project, then connect your Galaxy Note 10 to your PC or HDMI display to apply the finishing touches on a larger screen.
For those who do not have access to any peripherals, you can use your smartphone or tablet as a touchpad when connected to a display.
Furthermore, work files stored directly on your smartphone are secured by Samsung’s exceptional security technology.
How to set it up
Setting up DeX is simple. First, ensure you have the DeX app installed.
Users can then choose between connecting their Samsung devices to their PC or Mac via a USB-C cable, or to an HDMI display using the Samsung DeX Pad, USB-C to HDMI Adapter, or Multi Port Adapter.
Once you have connected your smartphone or tablet to your PC or display, you will be presented with a message on your Home Screen asking you to authorise the connection.
Tap continue and then tap start to allow access to Full Desktop mode.
Certain devices may enter Screen Mirroring mode automatically, and to switch to the DeX interface, simply tap the Samsung DeX notification and select DeX to enable the desktop-like interface.
The following devices are compatible with Samsung DeX.
Smartphones
  • Galaxy S8
  • Galaxy S8 Active
  • Galaxy S8+
  • Galaxy Note 8
  • Galaxy S9
  • Galaxy S9+
  • Galaxy Note 9
  • Galaxy S10
  • Galaxy S10+
  • Galaxy S10e
  • Galaxy Note 10
  • Galaxy Note 10+
  • Galaxy Note 10 5G
  • Galaxy Note 10+ 5G
  • Galaxy A90 5G
  • Galaxy Fold
  • Galaxy S20
  • Galaxy S20+
  • Galaxy S20 Ultra
Tablets
  • Galaxy Tab S4
  • Galaxy Tab S5e
  • Galaxy Tab Active Pro
  • Galaxy Tab S6
To find out more about Samsung DeX, visit the official Samsung website.
This article was published in partnership with Samsung.
Partner Content
Recommended
Share this article
