17.07.2024
Keep the conversation going with AirMobile by Afrihost
We know you have a lot to say, so why cut the conversation short or wait for a specific time before you call someone?
Until 31 October 2024, all calls made between AirMobile numbers will be free of charge. So you can talk all day, any time and actually laugh out loud.
AirMobile truly makes it easy from the get-go. Simply download the AirMobile app (available on iOS, Android and Huawei) and follow the prompts.
You can get connected in under 10 minutes if you have an eSIM-compatible device, or get a physical SIM card delivered to your door for free.
Try AirMobile for free
Not sure if AirMobile is the right fit for you? You can try AirMobile for free.
Once your SIM is active on the AirMobile network, as part of the launch promotion, you’ll get 3GB mobile data and R10 airtime for free.
Give 5GB. Get 5GB.
Every AirMobile number comes with a unique AirID promo code. You get 5GB data for every friend who signs up using your AirID.
Plus, your friend will also get 5GB data. This is activated once your friend has RICA’ed their SIM card and verified their payment details.
Share the love with AirShare
The AirShare feature allows you to share data and airtime with any other AirMobile user. You can make a transfer online or via the App.
Manage it all from the app
The AirMobile App puts you in control of everything – manage your SIM, top up, make payments, view detailed usage stats and get legendary support.
