24.07.2024
HUAWEI Launches MateBook X Pro Featuring Sleek Design and Superior Performance
The HUAWEI MateBook X Pro has made its debut in South Africa, giving the local consumer a laptop that brings together innovative technology, aesthetic design, and a smart experience to ensure superior performance packed in a super sleek body.
Slimmed down to 13.5mm1, it represents a new standard in lightweight laptops weighing under 1kg. A mere 980g2, the laptop is equipped with an Intel® Core™ Ultra 93 processor and features a powerful 40W Thermal Design Power (TDP) rating.
Aesthetic design and superior portability at a glance
The new HUAWEI MateBook X Pro weighs just 980g2 and has been slimmed down to a staggering 13.5mm1. This is the first laptop to feature a four-axis CNC on both sides, forming a graceful slope with a subtle gradient curvature called the Skyline Design. This accentuates the laptop’s smooth feel and refined look.
The laptop’s trend-setting silky-smooth metallic body is easy on both the hands and the eye. Its coating is highly scratch-resistant, and stains can be wiped off with ease. Available in Morandi Blue and White colour schemes, this palette complements the metallic body, providing a fusion of oriental aesthetics and minimalist elegance.
A new standard in laptops weighing under 1kg
Laptops with state-of-the-art processors usually weigh more than the MateBook X Pro, which, despite being equipped with a next-generation Intel® Core™ Ultra 93 processor, weighs just 980g2 and is only 13.5mm1 thick. This represents a new standard in laptops weighing under 1kg.
Additionally, the HUAWEI MateBook X Pro strikes a balance between performance and portability with the innovative HUAWEI Cloud Falcon Architecture. An intricate internal design that extends from the PCB to each of its individual components.
The modular PCB takes up less space and enables larger fans, batteries, and speakers to be accommodated within its slim design. The laptop features superior performance in heat dissipation, audio experience, and battery life
Innovative technologies enable superior performance
The HUAWEI MateBook X Pro features the all-new Intel® Core™ Ultra 93 processor, offering up to 40W TDP.
Its dedicated HUAWEI Shark Fin heat dissipation system features an innovative 3D air intake and exhaust design, ensuring airflow from all sides. Holes are opened on the backlight plate of the keyboard to allow cool air to flow into the device from the keypad. This significantly reduces the temperature of the keyboard.
The more space-efficient HUAWEI Cloud Falcon Architecture allows for larger fans and HUAWEI has applied AI to its fan blade design and introduced streamlined pressurised fan blades. The intelligent AI temperature control algorithm used has undergone rigorous learning to ensure ultimate resource optimisation.
In addition, the laptop’s ultra-thin Vapor Chamber (VC) heat dissipation module further enables superior heat dissipation.
The popular HUAWEI-developed Super Turbo4 technology has also received an upgrade to support dynamic software acceleration during intensive tasks, in addition to intelligent resource scheduling, seamless power-on, and second-level software startup.
Adobe Premiere Pro 4K video rendering is 1.69x faster, Filmora 4K video export is 2.18x faster, and VSCODE compilation is 1.27x faster on the HUAWEI MateBook X Pro than on the previous generation.
The new laptop’s battery capacity has been upgraded to 70Wh from the previous generation’s 60Wh, enabling a staggering 11 hours of local video playback. Using 90W SuperCharge Turbo mode, you can work on office tasks for 2 hours after just 10 minutes of charging5.
New breakthroughs in display
Since the launch of the HUAWEI MateBook Series, the 3:2 productivity screen has won wide acclaim from consumers worldwide for its high screen-to-body ratio. The new HUAWEI MateBook X Pro has a 14.2-inch 3:2 flexible OLED screen and a screen-to-body ratio of up to 93%6, offering a wider range of view, and a more immersive viewer experience.
The HUAWEI MateBook X Pro comes standard with HUAWEI X-True™ Display. 3.1K (3120 x 2080) resolution and a 120Hz refresh rate7 that ensures a crystal-clear display. Moreover, the colour display of each HUAWEI MateBook X Pro screen has been calibrated before delivery.
The meticulous colour accuracy of ∆E < 18 is achieved in Adobe RGB, sRGB, and P3 colour ranges, which enables accurate colour displays at all times. The laptop’s 1000-nit9 peak brightness and 1,000,000:1 contrast ratio provide true-to-life brightness contrasts. A paper-like viewing experience that’s easy on the eyes is enabled by the screen’s smart colour adjustments.
AI-powered productivity and customisation
The HUAWEI MateBook X Pro collaborates seamlessly with mobile phones, tablets, and earphones via the popular Super Device feature. And HUAWEI AI Camera and AI Sound capabilities provide an unparalleled online conferencing experience. AI Search supports cross-device search and locates keywords and related content in documents across devices, further improving work efficiency.
The HUAWEI MateBook X Pro strikes the perfect balance between sleek design and exceptional performance. With its innovative technology, the laptop is an ideal productivity and creativity tool for all users, regardless of your environment or application.
Explore the HUAWEI Online Store to secure your HUAWEI MateBook X Pro Core Ultra 9 with 32+2TB for R44,999.00 in blue. Alternatively, opt for the HUAWEI MateBook Pro X Core Ultra 7 with 16+1TB in white for R39,999.00. You can also purchase the white model through our partner Vodacom at R1,499.00 per month over 36 months.
[1] Data comes from Huawei labs and is the thickness of the device body measured at the center of the rubber feet along the lip on the front edge.
[2] Data comes from Huawei labs. Actual weight of the product may vary depending on the configuration, manufacturing process, and measurement method. Actual product shall prevail.
[3] Intel® Core™ Ultra 9 185H and Ultra 7 155H processors are available. Actual configuration shall prevail.
[4] Only certain Huawei laptops running PC Manager 13.0.3.390 or later support this feature, and more models will be available to support this feature in the future. If you have any questions about the overall experience, usage restrictions, or models supported by this feature, please contact your local Huawei customer service hotline.
[5] Data comes from Huawei labs and is obtained using PCMark 10 Modern Office when the device in sleep mode is charged using the original 90 W charger for 10 minutes from the battery level of 2%. Actual performance may vary depending on the individual device, usage habits, and environmental factors.
[6] Data comes from Huawei labs. Measurement is based on the size of the visible area of the screen in proportion to the screen size. Actual product shall prevail.
[7] Data comes from Huawei labs. The refresh rate is automatically adapted depending on the app page. Actual experience shall prevail.
[8] ΔE<1 is a typical value of the average color accuracy before delivery. Data comes from Huawei labs. The color accuracy may vary slightly depending on the screen usage duration, test instruments, and other factors. Actual usage experience shall prevail.
[9] Typical data and can be achieved when HDR content is displayed.
