Samsung Odyssey OLED G6 – The ultimate monitor for hardcore gamers
The Samsung Odyssey OLED G6 monitor has arrived in South Africa and is the ultimate display for hardcore gamers.
From competitive online shooters that require lightning-fast response times and refresh rates, to the most graphically-intensive AAA titles that need accurate colours and sharp pictures – the Odyssey OLED G6 does it all.
We detail the top features the Samsung Odyssey OLED G6 gaming monitor offers, below.
A breathtaking experience
Your gaming experience will reach new heights with the Odyssey OLED G6.
The monitor’s 27-inch OLED display delivers incredible image sharpness and colour clarity that vastly exceed the IPS and VA monitors that most gamers currently use.
This is thanks to OLED technology allowing each pixel to emit its own light, enabling pinpoint delivery of deep blacks, bright whites, and incredibly colour-accurate imagery across the entire panel.
Samsung has complemented this with a 1440p resolution, a 360Hz refresh rate, and a 0.03ms response time in the Odyssey OLED G6 – ensuring that you smash every gaming session out of the park.
Competitive online gamers will benefit hugely from the 360Hz refresh rate, which combines with the unprecedented 0.03ms response time to smoothen gameplay and improve your fast-twitch accuracy.
Graphically-intensive single-player games also benefit immensely from being played in the higher 1440p resolution and on the colour-accurate OLED panel.
Impressive technology
The incredible display quality of the Samsung Odyssey OLED G6 monitor is powered by its industry-leading NQ8 AI Gen3 processor.
This is the same chip used by Samsung in its 8K TVs and is so powerful it can upscale the visual quality of your games as you play.
AMD FreeSync Premium Pro and Core Lighting+ are additional features on offer with the Odyssey OLED G6 and provide the following benefits:
- AMD FreeSync Premium Pro – Market-leading technology that eliminates choppiness, decreases screen lag, and removes image tearing.
- Core Lighting+ – Uses ambient lighting to synchronise the display with its surrounding environment.
These technologies combine to make your games look incredible at all times.
Design and durability
A notable advantage of using the Odyssey OLED G6 over other high-end gaming monitors is its excellent durability and long lifespan.
This is enabled by its Safeguard+ display protection feature, which prevents burn-in by reducing overheating – courtesy of a built-in pulsating heat pipe in the monitor.
Additionally, the display’s ergonomic, sleek metal design makes it easy to position in any space – and it can pivot up to 92 degrees in both directions while supporting a 30-degree swivel.
The Samsung Odyssey OLED G6 rounds out its impressive design by offering all the ports you will ever need – including DisplayPort, HDMI, USB, and a headphone jack.
Samsung has thought of it all with the Odyssey OLED G6 – from incredible refresh rates and stunning image quality to a great design and a wide range of ports.
Click here to learn more about the Odyssey OLED G6.
