5.11.2024
LED Frames taking over from Snapper Frames and Bulky Lightboxes
AM.co.za has launched its newest brand, LED Frames, which is the future of the signage industry.
These displays are engineered to replace the snapper frames and the bulky, inefficient lightboxes that have traditionally been used in the signage industry.
LED Frames are available in single-sided and double-sided variants, and stand apart for their incredibly lightweight and thin design.
These frames are just 10mm thin for single-sided frames, and 20mm for the double-sided alternatives.
They are built of tempered glass to ensure they deliver long-lasting performance exceeding that of traditional snapper frames.
What truly sets these frames apart is that they deliver super bright lighting without needing a lightbox – ensuring your signs or banners are easy to see at all times.
Their built-in, innovative LED technology ensures your sign uses less electricity than traditional lightboxes while maintaining top-tier brightness distributed evenly across the display.
All of this is available at a more affordable price than a traditional snapper frame – despite snapper frames still requiring you to buy separate lightboxes to illuminate their contents.
Watch this video to learn more.
Endless options
LED Frames offers a wide selection of sizes and product types for you to choose from – all available individually or in bulk.
The most popular LED Frame products are detailed below:
  • LED Frame A1 – A1-sized LED frame with single-side lighting and 10mm thickness. Requires a DC 12V 2A power supply.
    • Single – R1,099
    • Box of 10 – R7,399
  • LED Frame A2 – A2-sized LED frame with single-side lighting and 10mm thickness. Requires a DC 12V 2A power supply.
    • Single – R539
    • Box of 20 – R7,799
  • LED Frame A3 – A3-sized LED frame with single-side lighting and 10mm thickness. Requires a DC 12V 1A power supply.
    • Single – R329
    • Box of 20 – R4,699
  • LED Frame A4 – A4-sized LED frame with single-side lighting and 10mm thickness. Requires a DC 12V 1A power supply.
    • Single – R219
    • Box of 20 – R3,099
  • LED Frame 6090 – 600 x 900mm LED frame with single-sided lighting and 10mm thickness. Has AC220V 32W integrated power supply.
    • Single – R1,099
    • Box of 10 – R7,899
  • LED Frame 8012 – 800 x 1200mm LED frame with single-sided lighting and 10mm thickness. Has AC220V 42W integrated power supply.
    • Single – R1,499
    • Box of 10 – R10,999
  • LED Box 6090 – 600 x 900mm LED lightbox frame with double-sided lighting and 20mm thickness. Requires DC 24V 2A power supply.
    • Single – R2,099
    • Box of 6 – R8,999
  • LED Hang 3560 – 350 x 600mm Edgeless LED suspended hanging frame with double-sided lighting and 20mm thickness. Has 220V 14W integrated power supply.
    • Single – R1,099
    • Box of 6 – R4,399
  • LED Hang 3590 – 350 x 900mm Edgeless LED suspended hanging frame with double-sided lighting and 20mm thickness. Has 220V 20W integrated power supply.
    • Single – R1,299
    • Box of 6 – R5,299
  • LED Hang 3512 – 350 x 1200mm Edgeless LED suspended hanging frame with double-sided lighting and 20mm thickness. Has 220V 26W integrated power supply.
    • Single – R1,799
    • Box of 6 – R7,499
Click here to buy LED Frame displays individually.
Click here to buy LED Frame displays in bulk.
Which is your go-to online retailer for tech products?
