12.11.2024
Protect your gate motors, gates, solar panels, and more with VALARM
VALARM by Disrupter Technologies is the easiest way to defend your home or business against theft and unauthorised entry.
VALARM is a compact vibration detection unit that is installed in key areas of your property to enhance your security setup.
It uses a fine-tuned sensor to pick up unauthorised tampering and triggers an alarm system – or a standalone siren if you prefer to use VALARM as your primary security device.
Watch the video below to learn more about VALARM.
How VALARM works
The biggest selling point of VALARM is how easy it is to set it up.
Users can easily install the device in under 10 minutes on anything from gate motors and garage doors, to gun safes and generators.
It then uses smart vibration detection as its trigger – meaning it will sense everything from a gate opening without authorisation, to an intruder trying to open your safe, or criminals breaking open outdoor telecommunications and power distribution cabinets, and even tampering of CCTV surveillance poles
The sensitivity of the sensor can be fine-tuned to your preferences, and for most applications, it simply works out-of-the-box with the default sensitivity.
VALARM is also great for protecting your solar panels – which have become a prime target for South African thieves.
If a robber attempts to loosen a solar panel protected by VALARM, the vibration from this action will trigger the alarm.
Compact size
VALARM’s small size ensures it’s easily hidden no matter where it is installed – underneath your solar panels, inside a gate motor, inside your safe, and in various other ways.
When it is run in standalone mode, it only draws 1mA – allowing it to run for up to six months on a standard 12V 7Ah battery.
Business application
Along with being an excellent option for home security, VALARM is a great choice for companies looking to secure their offices, remote warehouses, and equipment.
The VALARM unit’s firmware can even be customised to match your business’s unique needs, and you can contact Disrupter Technologies with your company’s requirements at any time.
VALARM can be equipped with a long-range transmitter and other external communication devices, too, allowing it to connect to a distant alarm system or control centre in industrial situations.
Buy VALARM today
If you would like to buy VALARM units for your home or business, contact Regal Security – the South African distributor for Disrupter Technologies.
Regal Security is a world-class security solutions provider and the preferred distribution partner for many of South Africa’s top brands.
Click here to learn more about the VALARM vibration unit.
