17.01.2025
How to keep your car in perfect condition between journeys
Following the festive season and your exciting holiday travels, it is important that you perform preventative maintenance on your vehicle.
This is essential as cars travelling long distances can easily pick up minor issues that can eventually become far larger problems.
Preventative maintenance ensures these minor issues are detected and solved early, keeping your car in prime condition for your next 2025 adventure.
Midas has compiled 6 important areas to perform preventative maintenance, below.
Step 1 – Fluids
The first step is to inspect your vehicle’s essential fluids, including engine oil, coolant, brake fluid, transmission fluid, and power steering fluid.
Ensure each of these is topped up because your vehicle could be seriously damaged if these fluids run low.
Midas offers a wide range of high-quality fluids to suit most vehicles – ensuring optimal performance and longevity.
Steps 2 – Tyres
Inspect your vehicle’s tyres for signs of wear and tear, such as uneven tread wear, cuts, or punctures.
You should also check your tyre pressures and rotate them if needed. On average, most tyres should be rotated every 8,000 to 10,000 kilometres.
Proper tyre care provides peace of mind and extends your tyres’ lifespans, saving you money.
Step 3 – Battery
Long road trips can take a heavy toll on your vehicle’s battery.
You must therefore check your battery to see if it is weak or old and ensure the battery terminals are clean and corrosion-free.
Step 4 – Brakes
You should inspect your brake pads and rotors for any signs of wear – as this could lead to a serious safety issue.
Should you find squeaking, grinding, or reduced braking performance, you should immediately replace the worn components by visiting your nearest Midas store.
Ensuring your brakes are in 100% condition is vital for peace of mind and safety on the road.
Step 5 – Belts and hoses
Inspect all your vehicle’s belts and hoses for cracking, fraying, or leaks.
Replacing these sub-par belts and hoses ensures you won’t encounter any failures while travelling.
Midas supplies an excellent selection of durable belts and hoses for almost any car brand.
Step 6 – Filters
Finally, you should replace your vehicle’s air and cabin filters to keep your air conditioner’s air quality and performance excellent.
These simple steps will ensure your vehicle will be ready to drive in 2025 without any issues.
Midas is the ideal partner for keeping your vehicle in top condition – click here to shop at Midas.
