19.03.2025
Lithium Batteries SA (LBSA) launches Locally Developed high-voltage battery for businesses
Lithium Batteries SA is a leading developer of world-class energy storage solutions.
The company started off in the garage of a homeowner who faced an obstacle and came up with a solution.
The homeowner, Bain Viljoen, had just bought his first property, and was battling with an unstable supply of municipal power.
However, the solar batteries and backup power solutions available on the market were exorbitantly priced.
To solve this problem, Viljoen founded Lithium Batteries South Africa – and what was once a new source of extra income has evolved into a major player in the South African battery manufacturing market.
The company now employs over 50 staff members across Johannesburg and Cape Town and supplies over 800 South African solar distributors and installers with world-class battery solutions.
Furthermore, since its inception in 2019, Lithium Batteries South Africa has produced over 28,000 low-voltage batteries.
Lithium Batteries SA is now taking the next step in its business growth journey with its newly launched high-voltage battery.
High-voltage battery
Lithium Batteries South Africa has developed a high-voltage battery that is manufactured locally and is targeted at South African users.
It is designed to be affordable while still delivering excellent performance across various applications – most notably in commercial and industrial settings.
The new high-voltage battery is a versatile offering that can be used to build systems ranging from 24kWh to 6mWh, across shopping centres, schools, hospitals, and factories.
Lithium Batteries South Africa offers all the components you need to build this system, included racks, controller units, battery modules, discrete cabling, and even full rack assembly.
You will also enjoy the following benefits:
  • Fast assembly – Quick and effortless to put together thanks to a wire-free design.
  • Easy module securing – The control and module slot easily into place thanks to a secure drawer lock.
  • Seamless module switching and balancing – This allows for easy module replacement in the case of a fault.
  • Battery synchronization – This high-voltage battery has a powerful bidirectional current limiter that synchronises new batteries into your system.
  • Flexible modules – Use between 4 to 14 modules to cater to your specific inverter and budget needs.
  • Large expansion – Parallel up to 60 batteries with auto master-slave assigning with fail over protection.
By using these batteries, South African businesses also contribute to the local economy by purchasing from local manufacturers.
Contributing to local communities is an integral part of Lithium Batteries SA’s business model, too, as it has played an active role in installing systems for non-profit organisations, schools, and feeding schemes.
To learn more about Lithium Batteries South Africa’s new high-voltage battery, click here.
