9.02.2026
Private APN SIMcontrol – Secure, pooled, multi-network mobile data on one platform
Businesses don’t just buy data SIMs, they buy predictable, secure connectivity for critical devices that keep operations moving – from POS terminals and security systems to smart meters, IoT sensors, hand-helds, and vehicle trackers.
That’s where Private APN SIMcontrol delivers a modern way to run a private mobile APN.
Public mobile data routes traffic over the open internet.
That’s fine for phones, but not always ideal for connected devices that handle card transactions or telemetry, or company devices that need to be locked down to only access specific destinations on the internet.
Typically suited for larger deployments of more than 200 SIMs, a private or corporate APN provides your data SIM fleet with a dedicated, isolated data path, with fixed/static IPs and custom firewalling.
This ensures that traffic stays off the public internet, and you decide what gets in or out, resulting in better security, better visibility, pooled data, and fewer “mystery megabytes”.
Why SIMcontrol’s approach is different
Traditional private APN setups are powerful but often complex to deploy and painful to manage.
SIMcontrol removes that friction through the following features:
  • One platform – Manage SIMs from all major South African networks (and selected African markets) from a single account, bring your existing SIM base or source new ones in bulk, and manage “normal” contract or prepaid SIMs on the same platform.
  • Private by default – Keep device traffic off the public internet with fixed/static IPs, custom firewalls, IMEI/device locking, and allow/deny lists for traffic destinations.
  • Pooled data across networks – Buy one pool of data and share it across SIMs and networks, with per-SIM quotas to prevent overuse while eliminating bill shock and out-of-bundle risk.
  • Real-time control – See live sessions, tower locations, set usage rules and alerts, block apps or destinations, and act instantly, all from a clean, web-based dashboard.
  • Built for scale – Whether you run hundreds or hundreds of thousands of company SIMs, you get automation, advanced reporting, and APIs to plug SIMcontrol into your existing systems.
  • Tier-1 technical support – Access a local expert team with over 15 years of experience that understands enterprise connectivity, IoT, retail, security, fleet and industrial deployments.
SIMcontrol provides control over a private APN without the operational drag of managing it day to day.
Architecture in brief
Private APN SIMcontrol runs as APN-as-a-Service, offering the same core components you’d expect in a private APN (RADIUS, IP allocation, firewalling, routing, and logging) but delivered as a managed platform:
  • APN access on major South African networks
  • SIM-level policy engine for quotas, rules, and alerts.
  • Centralised data pool shared between networks with no contract or term commitments
  • Online SIM management platform and APIs for operations, finance and integrations.
  • Advanced network security and full geo-redundant network infrastructure.
  • Not just for private APN – better manage contract, prepaid or global roaming SIMs on the same platform & account.
Migration without mayhem
Those already running a private APN with no control, no pooled data across networks, and no contract flexibility will also find SIMcontrol of value, as existing APNs can be migrated in phases:
  1. SIMcontrol helps clean up your existing SIM base to identify only actively used SIMs.
  2. Map your current routing and firewall policies.
  3. Add usage quota rules, alerts and user-level controls. Migrate SIMs in batches or as a whole, depending on your device types – no “big bang”.
  4. Validate usage and billing with live session monitoring and reporting.
Teams keep their workflows, and you gain real-time visibility with fewer moving parts.
Key to this is that SIMcontrol has over 15 years of experience in enterprise SIM management, manages over 1 million SIMs, and has over 1,000 businesses relying on the platform across South Africa and beyond.
SIMcontrol is a multi-award-winning telco partner that works closely with leading mobile networks across the continent.
Try it the easy way
Qualifying businesses can get a no-commitment free trial to see Private APN SIMcontrol in action – including a live account, test data, and test SIMs to prove the value it will offer in your environment.
The bottom line is that if your devices keep your business running, you need a managed private APN without headaches.
Private APN SIMcontrol delivers real-time SIM management on one platform, so your teams spend less time fighting connectivity and more time shipping value.
Click here to learn more about SIMcontrol.
Which is your go-to online retailer for tech products?
