24.11.2026
Codehesion code audits fix your flawed software before it becomes a bigger business problem
Codehesion, South Africa’s leading software development company, has worked with many of South Africa’s most prominent businesses.
From startups to large enterprises, there is one underlying trend it has noticed.
Businesses often have flaws in their code that they are unaware of, because the code still seems to be working properly.
The reality, however, is that the software in question is either running suboptimally, or at risk of collapsing completely as your business scales.
There is one simple reason for this: the software was not built with the future in mind.
This is known as architectural debt, and it often isn’t evident until it is too late.
Therefore, Codehesion encourages South African businesses to undergo a code audit to determine whether their software is appropriately developed, or if there are underlying flaws.
When Codehesion does a code audit, it analyses your organisation’s existing software.
Based on this analysis, it identifies areas where your business is at risk and compiles them into a report it will share with you.
Then, if you give Codehesion permission, it will go ahead and fix your code.
It begins with the code fixes that deliver the most business value in the shortest amount of time.
Then, it will address the other issues that are less of an issue in the short term but could become larger issues down the line.
This way, your immediate needs are prioritized, without ignoring the importance of being futureproof.
Contact Codehesion today to get a code audit.
