Join us now. It is free, and it takes less than 1 minute to register.
Register now
Subscribe to our daily newsletter. It is free, and it comes with many benefits.
+ Reply to Thread
Page 4 of 16 FirstFirst 1234567814 ... LastLast
Results 46 to 60 of 239
Thread: gr8signal - help to measure SA's mobile networks
  1. #46
    Banned marine1's Avatar
    Join Date
    Sep 2006
    A black hole in the universe - JHB
    Posts
    45,945
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by gr8signal View Post
    Hi marine1
    Sorry not totally sure if I understood the question correctly.
    The signal strength is independent of what connection type your using. If I understand correctly android reports on the capability advertised by the tower and what its allowed to use(If you say only edge it will only report that) and that's what we'll record.
    When you disable data you are more telling your phone not connect to the data network but it can still see it.
    This is what testing seem to indicate.
    Though this may differ from phone to phone. For instance some phones only report bars, some only dBm and some both.
    Hope I've answered the question you asked.
    Excellent thats exactly what was asked and you answered it 100%.
    Will be uploading as often as humanly possible.
  2. #47
    Master
    Join Date
    Jan 2009
    Centurion
    Posts
    655
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Great idea and awesome app.
    My perception of my signal strength at home is that it depends a lot on the time of day. How is this handled by the app/site? If it shows a green patch at a specific location-service provider point, I assume this is just the average of all inputs received. It would be interesting to see how this changes for peak and off-peak period. Maybe a 'time of day' filter on the map, similar to Google Maps's traffic filter.
  3. #48
    Grandmaster
    Join Date
    Jul 2009
    Posts
    2,925
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Gr8 stuff!
    I'll be installing this later.
    So just to clarify, the app logs signal strength all the time, presumably as you connect to different cell towers etc. Then, when you connect to wifi it uploads all the logs?
    Hence, keeping my data connection off most of the time won't affect it, right?
    <profound><witty> One Liner </profound></witty>
  4. #49
    Join Date
    Sep 2006
    Posts
    45,945
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Default
    What seems to be happening all over, well so far at least, on Vodacom, signal is anything but stable, percentages fluctuate from 15% - up to 100%.
    It happens literally a few meters away.
    So you would be on 100% then drive a few meters down the road and it drops to 20%.
    Interesting how the signal is not stable at all, this is in Douglasdale, Fourways area.
    I have uploaded the stats.
  5. #50
    Super Grandmaster
    Join Date
    Jun 2004
    Mama Randburg, middle of everywhere
    Posts
    6,442
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Once registration is done and you've logged in you'll now have a "My Data" link available on the top right. Once you've clicked on that it will take you to where you can get your tracking id to paste into your phone under settings.
    Once you've logged some data with the tracking ID you can download it from the same location.
    Okay thanks, having gotten over my PICNIC error I'm registered and set to go - in turbo mode, FWIW. So now, I'll get data only post-reg, yes?
  6. #51
    Join Date
    Sep 2006
    Posts
    45,945
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Default
    I doubt the networks will be too happy about this.
  7. #52
    King of de Jungle LazyLion's Avatar
    Join Date
    Mar 2005
    District 9
    Posts
    99,339
    Blog Entries
    21
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Default
    I've had it installed since the MyBB conference, but I'm not sure what it is supposed to be doing.
    Quote Originally Posted by Swa View Post
    It's ignorant to think that reason and science necessarily leads to progress.
  8. #53
    Join Date
    Sep 2006
    Posts
    45,945
    Mentioned
    5 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by Garyvdh View Post
    As I understand it, you use it, hit upload and it logs on the map, quality of the network you are on etc.
    Then you go onto the map and you can actually see REAL stats and quality of the networks and not rely on their rubbish advertising
  9. #54
    Join Date
    Mar 2005
    District 9
    Posts
    99,339
    Blog Entries
    21
    Mentioned
    2 Post(s)
    Tagged
    0 Thread(s)
    Default
    OK, I can see my signals around my house (which look pretty weak), but I can't see any signals uploaded around my office.
  10. #55
    Super Grandmaster
    Join Date
    Jun 2004
    Posts
    6,442
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by marine1 View Post
    TFB, it's not like they care about responding to us, telling us the truth or, you know, giving more than a flying duck about us beyond billing.
  11. #56
    Join Date
    Oct 2012
    Posts
    88
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by Borrels View Post
    Hi Borrels
    The application when not in turbo mode logs signal every 5 minutes and then attempts to upload every 15.
    When in turbo mode it will also log on tower change (In future versions this will change to x meters moved when in turbo mode).
    So it should get the signal variation through the day. Currently we are only plotting average while the the map get's filled in.
    We are planning on showing more map variations as time goes buy to try give more relevant information.
    I know the team is hoping to release the tower layer later today.
  12. #57
    Join Date
    Oct 2012
    Posts
    88
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by K3NS31 View Post
    Gr8 stuff!
    Hi Borrels
    Yes keeping your data connection off should have no effect on the logging.
    The logging is a mixture of tower change and time depending if in turbo mode or not.
  13. #58
    Resident Lead Bender Ockie's Avatar
    Join Date
    Feb 2008
    Henceforth AKA OckieMoto :-)
    Posts
    47,276
    Mentioned
    13 Post(s)
    Tagged
    0 Thread(s)
    Default
    Tower layer? What is that? To show where the towers are and who the tower belongs to?
    APoc184 - "Well apparently I'm Ockie's kinda girl."
  14. #59
    Join Date
    Oct 2012
    Posts
    88
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Hi marine1
    Yes I know some of the people in the office have started using it to wonder round with the app open to find the best signal before making a call when in a bad signal area.
    It interesting to see which spots in the office have better signal and which have bad.
  15. #60
    Join Date
    Oct 2012
    Posts
    88
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by bdt View Post
    Yes we will only show logs from the point where you put the tracking id in. It was the best idea we could come up with to try and reduce privacy issues.
    Also if you remove the tracking id logs from then till you put it back in won't appear.
+ Reply to Thread
Similar Threads
  1. Mobile Networks in Africa
    By F1 Fan in forum Cellular: Mobile Phones, Call Contracts, Content, MMS and SMS
    Last Post: 10-05-2012, 04:00 PM
  2. Replies: 60
    Last Post: 22-03-2011, 10:21 PM
  3. Virtual Mobile Networks
    By rpm in forum Broadband and IT News
    Last Post: 05-09-2009, 12:01 AM
  4. Porn straining mobile networks
    Last Post: 09-07-2009, 12:04 PM
  5. SA's mobile networks far cheaper and practical than UK
    By Frankie in forum Cellular: Mobile Phones, Call Contracts, Content, MMS and SMS
    Last Post: 04-07-2008, 02:50 PM
Tags for this Thread
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
