Join us now. It is free, and it takes less than 1 minute to register.
Register now
Subscribe to our daily newsletter. It is free, and it comes with many benefits.
+ Reply to Thread
Results 1 to 11 of 11
Thread: Best approach to extend wifi between 2 apartments
  1. #1
    Join Date
    Jun 2012
    Posts
    100
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Best approach to extend wifi between 2 apartments
    Hi All
    Really hoping one of you clever folk can help me out.
    My parents and brother are currently living in 2 different apartments in the same block of flats.
    The flats are separated by 1 other flat and on the floor above.
    ie, flat 1 is 101 on the first floor, and second flat is 203 (second floor).
    1 of the flats currently has a Fibre connection and therefore it makes sense to share the connection if possible, rather than paying an extra +-800pm for another fibre connection.
    At the moment the wifi signal does not reach the 2nd flat.
    How can we best extend the wifi range, bearing in mind we don't have access to the flat in between.
    They would be happy to purchase an expensive router/range extender as this would still be much cheaper in the long run.
    Thanks alot!!
  2. #2
    Grandmaster
    Join Date
    Jul 2009
    MyBroadband
    Posts
    1,480
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Illegal
  3. #3
    Grandmaster agentrfr's Avatar
    Join Date
    Jul 2008
    Sandton, Gauteng
    Posts
    4,548
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    What are the rules on mounting devices to the wall outside ? You could probably get away with two slim APs stuck to the outside wall on a common face both flats share.
    Otherwise if you are lucky both flats will be on the same grid phase and you can hook up some Ethernet Over Powerline adapters in each flat - just be sure you get a set with encryption and re-pair them away from factory settings, otherwise a neighbour might steal your internets and you'll never know
  4. #4
    Join Date
    Jun 2012
    Posts
    100
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by agentrfr View Post
    Sounds complicated....was hoping to simply extend the signal with a serious range extender
    @[email protected]@$$ why should it be illegal? its not being used without permission?
  5. #5
    Grandmaster Quey_Quick's Avatar
    Join Date
    Dec 2007
    Joburg
    Posts
    2,134
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by [email protected]@$$ View Post
    Illegal
    Why is that?
    I spent a lot of money on booze, birds and fast cars. The rest I just squandered - George Best
  6. #6
    Grandmaster rubber_otter's Avatar
    Join Date
    May 2009
    Posts
    1,087
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Default
    Illegal
    5Ghz is public, and they would not be crossing a road (which is, if memory serves, actually also not really relevant)
  7. #7
    Join Date
    Jul 2008
    Sandton, Gauteng
    Posts
    4,548
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by Mark051 View Post
    If you're going to set up internet for a whole flat, rather do it properly and not have intermittent issues in the future
    There's nothing worse than not being able to watch a YouTube clip solely because of dodgey Wi-Fi
  8. #8
    Grandmaster
    Join Date
    Jul 2009
    MyBroadband
    Posts
    1,480
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by rubber_otter View Post
    Quote Originally Posted by Quey_Quick View Post
    Why is that?
    Intentionally broadcasting a wireless signal across your boundary/property border you'll need a ICASA license. Not to mention that it is most likely a breach in your ISP Ts & Cs.
    It's like sharing your DSTV with your neighbors using extra view? So then 2 or 3 or how many households just share the cost of the premium package?
  9. #9
    Join Date
    May 2009
    Posts
    1,087
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Default
    He is not going to be broadcasting across boundary/property borders. Did you read the OP?
    Also, downloading torrents is also against their T's and C's. But you all do it anyways. What the ISP does not know won't hurt them. @Mark051 lemme know if you need help with the setup.
  10. #10
    Grandmaster
    Join Date
    Jul 2009
    MyBroadband
    Posts
    1,480
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I did read it that's why I said you are not allowed to do that. He is clearly broadcasting beyond his own property. The whole building doesn't belong to him. And FYI, downloading torrents is not against any ISP's Terms.
    What I was suggesting by my original post is that he should be careful asking for such information on a public place like here where we do have the presence of many providers.
  11. #11
    Join Date
    Jun 2012
    Posts
    100
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Just to be clear, I'm not looking to be doing anything illegal.
    If that is the case, I will not be looking at this approach.
+ Reply to Thread
Similar Threads
  1. Extend Wifi hotspot downstairs
    By reflex84 in forum ADSL and VDSL Discussions
    Last Post: 26-07-2017, 09:32 AM
  2. Using router to extend wifi signal
    By RisseN in forum Networking and Security
    Last Post: 19-08-2016, 05:29 PM
  3. Diagram extend wifi outdoor
    By Photosbot1 in forum Photography
    Last Post: 18-08-2015, 01:08 PM
  4. Best approach for home Wifi?
    By flarkit in forum Networking and Security
    Last Post: 18-09-2009, 02:58 PM
  5. Extend my Wifi signal.
    By Project X in forum PC Hardware and Gadgets
    Last Post: 24-01-2009, 08:23 PM
Bookmarks
Bookmarks
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
