Hallo everyone and thanks for making this a great site! Overall I think the Mywireless product is great and kicks ass, but I'm a bit disappointed in the service Sentech is offering their clients and clients to be...[
First off, when you go to the map on Sentech's page it indicates whether you have signal in your area. Very impressed with this online map, I found "Good signal" in my area (Pretoria - Willow Glen AH) and decides to order the product right there and then! After about 2 weeks I eventually receive the modem and very excited I switched it on only to find that it doesn't pick up any signal in my house! [
] Now completely peeed off I phone the call centre only to get told that "Althought you have very good signal in that area, you have to have line of sight with one of the base stations" Now why couldn't Sentech tell me that from the start? Anyway I went out and bought myself this "patch antenna" from Fastcom. The conector of the cable doesn't fit perfectly, but who cares it worx!
The problem however is the lenght of the cable. the max they have is 2.5m. Does anyone know where I can get an extension for this "patch antenna" to increase the length? I get pretty good signal on my roof, but the cable is to short to run it to my PC inside the house...
Appreciate any sugestions.
CW
CW
