Difference between Mecer Axpert Inverter & Axpert Type Inverter
mitchmagi
Hi all
Can anyone clarify if the R2k price difference is worth it ?
Mecer Axpert Type 3000VA (3000W) PURE Sine Wave Inverter (1200W PWM Solar Controller) vs
GeeWiz Axpert Type 3000VA (3000W) PURE Sine Wave Inverter - PS3K PLUS (50A PWM Solar Controller)
Any reason not to get the cheaper one ?
There's a bit more nuance to it
The original makers are Voltronic with their original Voltronic Axpert inverters
Then you have the rebranded Axperts that's basically relabeled
Then you have the Axpert clones that are either stolen tech,reverse-engineered or just copied with possibly worse-parts in
As to which is which,hard to tell unless they're inspected internally
